Why will my LG G3 connect to other wifi's but not my own?
A
AC Question
LG G3 will connect to other wifi but not my own.
My lg g3 suddenly won't connect to home wifi. It will connect to other wifi and other people can connect to mine. My friend has the same phone and his won't connect to my wifi either. So far I've tried replacing the router , forget and add network, and factory reset. Nothing works.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: LG G3 will connect to other wifi but not my own.
Try setting the router to use AES, not TKIP or TKIP+AES. (Some of the better routers, like Linksys, won't even work that way. I ended up buying a cheap Netgear WNR2000 [$40] and everything works if it's set to AES.)
asha_kanta_sharma
