Help - VIRUS !!! How can I get rid of it?
A
AC Question
Help - VIRUS !!!
During sync, using the LG PC Suite on my PC, I was asked to upgrade the LG PC Suite software - and I confirmed. Unfortunately, following that my LG G3 smartphone probably got infected by a virus, as follows: the LG logo appears on a black screen (as if powering up) and then returns to the black screen and then again reappears and so on an so forth without ever powering up - in a never ending loop. Please HELP !!! I don't want to make a hard reset, as my stuff hasn't been backed up.
Many thanks!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,592
4,733
113
Unfortunately, you may not have many options. The G3 doesn't allow the user to wipe the cache partition, and I don't think there's anything equivalent to Samsung's Odin program to try to reflash the firmware.
akbarramadhani12
