A
AC Question
I woke up today and my phone had a bright green screen on it saying something about it crashing and what not. the only two options that i was given was to press the volume up and put the phone into dload mode or to press volume down and to reset the phone. So i pressed the reset button and returned to the same screen. I did this 3 times.
Then i removed the battery and the SD card to see if that would do anything. Now my phone starts to boot up flashes a bright blue screen for a couple seconds and then goes black. Now it is unresponsive to everything.
The only way i can get the phoen to do anything is if i remove the battery, put it back, and boot up the phone but then i get the same problem as before. It's and expensive brick right now. help.
