A
AC Question
HELP! LG G3 stuck in brick and I can't change the build.prop
I rooted my LG G3 not too long ago and changed the model number in build.prop to the Galaxy S6 (SM-G920F) so that Snapchat would behave as it does on Galaxy. This went fine, but then when I started messing around with roms for xposed and trying to flash, I bricked it. Now when it boots it immediately shows and gets stuck on the [####] Fastboot Mode Started screen. I can get it into download mode and on the Firmware Update screen via my PC and I was going to flash the stock firmware onto my LG using LGFlashTool, except I just realized the model number is still stuck at SM-G920F! It still thinks its a galaxy so I can't flash any LG firmware onto it! PLUS because it's bricked I can't get into my phone to change the build.prop model back to D850. Can I change the build.prop from my PC? Could I try flashing the SM-G920F stock firmware onto it since that's what it thinks it is?
Thanks
Thanks
