Help i can't read write delete on sd card
batu9802
Active member
Dec 13, 2016
25
It does not read or move, delete etc from its own program or another file manager my device lg g3 marshmallow
Morty2264
Ambassador
Mar 6, 2012
22,922
1,053
113
Hi! I unfortunately don't know why this is happening to you - hopefully another user who looks at this thread will be able to assist you - but what I do recommend is to not do anything will your SD card until you either contact LG, a cellular repair shop, or get advice/input from a trusted source or user.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,600
4,739
113
If you unmount the card, remove it, and insert it into your PC, can the computer read it and perform operations on the files normally?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,600
4,739
113
The card is most likely corrupt or damaged. If you're able to, backup all of the data to your computer hard drive now. Then see if you can reformat it. If it still doesn't work after reformatting, then the card is damaged, and should be discarded.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,600
4,739
113
There must be something about the card that the phone doesn't like. If I were in your situation, I'd just get rid of that card (or use it only on PCs), and use a different one.
WillyC
