- Jun 7, 2015
- 511
- 0
- 0
I ran into something odd with my Verizon G4 last night. Before going to bed, I put it on the same old AC charger that I've used for years with my Galaxy S3. It's old, and probably low-current, but I've never had a problem with it.
This morning, my phone had only increased from 15% to 44%. Very strange. And when I looked at the graph from overnight, the charge level looked like a series of bumps and dips. It would climb, then drop, then climb, then drop, each time getting a little higher. I assumed maybe the old charger couldn't supply enough current and was overheating and shutting down?
So during the day I tried some other chargers. Same result using a cheap eBay one. The battery icon would show charging, but the graph would show the charge level going up and down, and barely making any progress. Borrowed a Samsung charger, *still* no better.
I noticed that the phone was sometimes rather warm, right around the camera. I started wondering if the phone was overheating, and throttling-back the charge current, perhaps.
It finally occurred to me to try the obvious: reboot. I rebooted the phone, and it was immediately fine. It stayed cooler, and the charge level steadily increased, still using that same Samsung charger.
The phone had been factory-reset on Friday, then I transferred my apps & data from my old phone, upgraded a bunch of apps, etc. Unfortunately, before rebooting, I did not try to figure out if something specific was causing trouble. I don't see the Task Manager that I had on my S3, so I'm not currently sure how to look for an app using a lot of CPU time.
My current theory is something was "stuck", and was drawing a lot of CPU cycles, making the phone warm. This made the battery discharge faster, and I do also think something (charge current? Or, conversely, CPU speed?) was being throttled up/down, as the charge level kept going up and down, even with the charger still connected.
See attached screenshots. The first was overnight. Up/down/up/down. The second is during the day, WiFi off, GPS off, trying different chargers. I'd leave each connected for a while, but the charge level kept going up/down (the smaller spikes/dips you see). The last shows when I rebooted in early afternoon, then the charge level climbed normally after that.
So if you see a weird charge log, try rebooting. This makes me curious what happens if you run an intensive benchmark, making the phone warm, while trying to charge.
