Need help with silent mode and enabling alarm
mge1201
107
Just got this beast of a phone, switching from the S6 edge. Love it. But need help with enabling these specific settings:
1. Silent ringer (no vibrate)
2. Silent notification for text, email, etc (no vibrate)
3. This is important: alarm sound ON
I'm sure I haven't found the proper combination in the sound settings yet. Any help is appreciated.
Thanks. I've set to Notifications to Priority only but under the Basic sound profile, the sound options are either Vibrate Only or "Sound" (an audible ringer). There is no option for "silent". What am I overlooking?
You are wanting the alarm to be audible but all other notifications and ringer to be silent, correct?
If you set Interruptions to priority only and don't have anything selected, then all notifications and ringer will be silent and the alarm will be audible if you select Sound or the alarm will vibrate if you select vibrate.
That's what was confusing me. I thought all the sound settings are connected. Did not know the Notifications options work independently from the Sound Profile. I think I'm set.
slackingfred
