Play services battery drain fix
maxburn
973
Re: Google Services...
I might have tracked this one down to Android device manager. I turned the admin back on for that app so I could get the tracking and remote wipe and play services jumped back up there. Turned that back off and redid the play services wipe, downgrade and repudiate and play services seems to be back to normal.
Really needs a couple of days to be sure about that.
maxburn
973
I noticed earlier today that all my smart unlock stuff was blown away, presumably because of the play services reset. I turned location unlock and Bluetooth unlock back on and a short while later play services was back at the top of the list for drain.
So maybe the location or Bluetooth smart unlock is the culprit? I'm guessing location.
I hadn't turned Android device manager din back on so I guess that wasn't it.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,359
245
63
^^^Like you, I'm inclined to think Location. I've also Force Stopped LG Health and LG Health Agent diagnostically, because I'm guessing that that must use Location reporting quite heavily. Seems promising so far, though I'm sorry to have to forego such a pleasing feature of the phone.
greydarrah
3,047
222
Have you tried this, "Actually I forgot but I ran into that too, turn off Android device manager and go back and try again. That's a play service too."?
I too am unable to uninstall Google Play updates (not an option), and I saw where someone suggested first turning off Android Device manager, but I can't even find that to try and turn off. Where is it?
Also, I was going to disable Google Fit, but I cannot find it anywhere on my phone.
Thanks.
maxburn
973
Thanks.
I was referring to the dministrator privilege for Android device manager. I'm not sure all that's necessary now though.
Try this instead; turn off all smart unlock options under lock screen, smart lock.
greydarrah
3,047
222
I don't think that will work for me as I have my screen lock set to "None."
vansmack
547
17
Whenever Google Play Services is eating battery, 9 times out of 10 it goes away if I simply toggle Airplane Mode for a couple of minutes. I seem to have to do this about every 3 days or so with this phone, which is only slightly more than my Nexus 5 since the 5.1 update.
GDMarshall
At this point my suspicion is directed at Googles Device Manager. My problems started soon after installing Device Manager. I even uninstalled it but it seems to still have administrator privileges on my phone. I disabled these to complete the re-install of the Google Services App mentioned elsewhere in this thread and then as an added precaution I removed my device from Device Manager, as follows
To remove devices from your account:
Use your phone's browser to go to google.commyaccount.google.com.
In the "Sign-in & security" section, touch Device activity & notification.
In the "Recently used devices" section, touch Review devices.
Touch the device you want to remove > Remove.
Could it be that keeping track of where my phone is located is what was draining my battery? Maybe I just had not installed thsi service properly but for now I'm staying well clear of it.
knowledge is power
