I managed to shatter the screen on my beloved LG G4 by sitting on it! I have replaced the bezel/screen/digitizer on my G4 (purchased June last year) with a OEM replacement. Right after replacement phone worked fine but the proximity sensor was not operating correctly because I had not installed the small rubber bushing that it sits in. Shortly after phone went into boot loop. After replacing the bushing and a hard reset, I am still having the boot loop issue. I assume that I have caused the now known "loose connection" issue to manifest by disassembling the phone to replace the screen despite taking great care in both disassembly and re-assembly. Everything worked perfect before disassembly, and everything worked fine after full assembly aside from the boot loop. I am convinced that this is not that big of a fix as I did not in any way force any of the components while changing the screen.
I need the seasoned minds on the forum (who never seem to let me down) to tell me what "loose component connections" get serviced when LG does the warranty work. Any advice on the method that LG uses to correct the issue would also be greatly appreciated. (Dont bother with the youtube links of oven baking and the like, Ive been there already, looking for a legit repair and preferably someone with experience inside of the phone)
Thanks in advance for any help. And sorry if my search did not turn up an already developed thread on this issue. I am now demoted to using my well worn gen 1 Moto-X until I resolve this issue or the Note 6/7 releases. Please help I need my big screen and OIS camera back ASAP!!!!!
