lg g4 only displaying numbers when incoming calls and out going calls
nick3536
4
this problem happened yesterday evening as I was calling someone and noticed that only number is being displaying nothing else so I don't know how to fix this. I had his number saved so any one can help me to solve this problem.
Welcome to Android Central! Are your contacts saved to your Google account, or only to the local Phone account?
And it was working normally just recently (i.e., showing the contact's name and picture with the incoming call)?
What happens if you delete the contact, then enter it again?
ya it was working fine before but yesterday I try to delete all the contacts from my phone and enter it again before I do that I copied all the contacts from my phone to Google account then I deleted all the contacts from my phone I got the message saying that 137 contacts deletes cannot be done what you want to do with this action with 2 option do nothing and other one was just hit ignore not sure so choose the do nothing so all the contacts came back in the phone and after 1 hour later I got a call at that time name was displaying I checked couple of times so I think problem is solved I guess however thanks for your time to read this post and reply it so I can resolve my problem. peace
tvelez83
