as of about a week ago, my battery life turned horrendous. didn't install or add anything. use multiple batteries. Cant make sense of this. any helpful tips to try and see what causes this?
Try clearing the device cache to see if that helps: https://support.sprint.com/support/...GKB86646-dvc8970002prd?INTNAV=LeftNav:Lang:ENas of about a week ago, my battery life turned horrendous. didn't install or add anything. use multiple batteries. Cant make sense of this. any helpful tips to try and see what causes this?
Anything in your usage that is heavy on screen power? (movies vs text)With my screen at 60% brightness, it drains 67% of my battery charge. I can't make it 6 hrs without recharging. Any dimmer, I can't see the screen unless Im in low light/night. My apps dont use a significant % of charge. Suggestions? Makes no difference which of my 3 batteries I use. Thanks
If I watch movies my battery drains in about 4 hours.Anything in your usage that is heavy on screen power? (movies vs text)
That big beautiful screen does suck down the battery....
Movies and animated ads will use the power, many games too.
Indoors I tend to run the brightness at abut 35%.
