Hi all,
I recently attempted to use the QuickCircle case on my H810, which I was told had a finnicky chance of working, however, it worked flawlessly first try with this pad:
https://www.amazon.com/Pictek-Wirel...ag=hawk-future-20&ascsubtag=UUacUvbUpU5727018
After that, however, it hasn't really worked right. I've only been able to get it to work right after powering the device off, which lets it charge until it's full, then stops. It then won't work again until I power cycle it again. When it's not working, the charging light on the pad flashes irregularly, not the regular flashing I'm used to that lets you know the device is incompatible. I've been told there's a possibility of damage to the wireless charging circuits on this phone, but it doesn't make sense that restarting would have any effect on this. Any help would be most appreciated, as I'm not sure this thing is still under warranty.
Thanks,
Jake
Thanks,
Jake
