1. Jeremiah Bonds's Avatar
    I chatted with someone on the XDA forum about screen on time and idle time. Turns out, Quick Memo MAY be draining some of our batteries and we don't know it. You have to manually force stop it, so.... I downloaded Greenify (i know.. don't hate) to hibernate that app. So far, I'm at nearly 2 hours SOT with 75% battery left.. That's WAY better than I was getting. I was averaging maybe 4 hours of screen time.. Now it looks like I'll be getting way more. I'll keep testing this out, but this is literally all that I changed, besides download GSAM and activating the adb permissions so I can see what's chewing through battery (nibbling I should say)..
    revtech likes this.
    04-20-2017 04:41 PM
  2. Jeremiah Bonds's Avatar
    Because I keep forgetting to post screen shots.. This was today.. It's ok, but I got 5 hours of SOT while using about 45 minutes of GPS via Waze today.. Not bad.. I'm very happy with this finding.. It's literally only quick memo
    04-22-2017 05:31 AM
  3. Coraya's Avatar
    Interesting but unfortunate. Memo is very important to me. please leave long term updates regarding this because a third party memo app is not something I want to resort to. I always worry about battery issues with 3rd party apps.
    04-22-2017 06:14 AM
  4. Coraya's Avatar
    I force stopped it but I also noticed that it says it's always running 100% of the time.
    Jeremiah Bonds likes this.
    04-22-2017 06:17 AM
  5. Jeremiah Bonds's Avatar
    Yeah I still use it.. I just have it greenfield
    04-22-2017 10:33 AM
  6. dunamis's Avatar
    wonder if it's caused by the sync? I turned mine off and I do after reading this manually close the app.
    04-22-2017 12:26 PM
  7. Ryano89's Avatar
    I'm considering trying this on my V20. I will have to use greenify as well because I don't want to disable the app since I do use it.
    04-22-2017 03:58 PM
  8. Jeremiah Bonds's Avatar
    Yeah it might work.. I would have never thought about it.
    04-22-2017 05:06 PM
  9. Jeremiah Bonds's Avatar
    My phone drained like 20 percent over night but I'm still going to get at least 4 hours of screen time.. I don't even know why I had that drain either.. We'll see. Haha
    04-23-2017 05:13 PM
  10. Jeremiah Bonds's Avatar
    Here we go, with my battery drain overnight.. I still got over 4 hours of screen time..
    04-23-2017 07:04 PM
  11. Fret Madden's Avatar
    QuickMemo can't be disabled on my G6, and it appears to be tied into all system software to where greenify has no effect. I just keep checking it every so often to see if it needs stopped. It's a little bit better with it not running but it still seems to draw some battery somehow.
    04-23-2017 11:53 PM
  12. Jeremiah Bonds's Avatar
    Seems like you can't disable the app if you're on Verizon.. Or ATT.. One of them.. I can uninstall mine.
    04-23-2017 11:55 PM
  13. Fret Madden's Avatar
    Seems like you can't disable the app if you're on Verizon.. Or ATT.. One of them.. I can uninstall mine. http://uploads.tapatalk-cdn.com/201...6c90ce914d.jpg
    That's a handy feature. When you tap on battery does it list most or all of the system components? Just curious to see what Verizon did to make it different.
    04-24-2017 12:08 AM
  14. Jeremiah Bonds's Avatar
    I actually uninstalled it. Hahaha can't check the battery info, but GSAM battery from the play store has some info
    04-24-2017 12:18 AM
  15. Fret Madden's Avatar
    Ugh more differences - gsam won't work even after I enabled stats via ADB, but I can view QuickMemo's drain from the built-in monitor.
    04-24-2017 12:24 AM
  16. Jeremiah Bonds's Avatar
    That sucks.. GSAM did work for me one day and didn't the next, I had to redo the ADB
    04-24-2017 02:06 AM
  1. Moto Z Play locked how to enable usb debug so I can recover and backup files
    By AC Question in forum Moto Z Play & Z Play Droid Edition
    Last Post: 04-20-2017, 10:44 PM
  2. Replies: 1
    Last Post: 04-20-2017, 05:49 PM
  3. Quick Touch Banner for Messages before Android 7 update?
    Last Post: 04-20-2017, 05:34 PM
  4. Sprint Customer here. Trying to activate my new S8 and failing to activate
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 05:22 PM
  5. Coming from an iPhone? 150+ S8/+ tips and tricks in an hour long video
    By Highrisedrifter in forum Samsung Galaxy S8 & S8+
    Last Post: 04-20-2017, 03:42 PM
