Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By JoshKsky
    Default Lucid 2 Stuck In Weird Voice Output Mode
    I must have pressed a sequence unintentionally, because my Lucid 2 is stuck in some kind of bizarre mode and I can't get it out and it's very difficult to use.
    Symptoms:
    It announces every little thing I do. If I press the power button once, it tells me time out loud. Then if I wait it says "Screen off." If I rotate the screen it says "Landscape." Also "Device unlock" and "Showing items one to six of eleven."
    The touchscreen is very strangely behaved. If I touch an app, it surrounds it with a green square and says the app name. I have to double-click it to open it, and that's not reliable. It won't scroll down, so I can't look at half of the settings.
    Also, the drag-down menu doesn't work at all.
    How did I get here? How can I return it to normal? Thanks.
  2. #2
    Default Re: Lucid 2 Stuck In Weird Voice Output Mode
    Welcome to Android Central! Sounds like some Accessibility functions have been turned on. Go to Settings>Accessibility, and either turn off those specific functions, or turn off all of Accessibility.
    Thanks. That's what I thought -- except it won't allow me to scroll down in the settings menu to get to accessibility. In fact, now that I switched it to Beginner mode, I can't even get past the lock screen.
    OK, I got past the lock screen. Any idea how I can scroll downwards to find accessibility?
    I figured it out -- I needed to two-finger swipe to scroll to accessibility. Then I turned off TalkBack. Order is restored.
    B. Diddy likes this.
  1. LInes in the screen .. HTC One Mini
    Last Post: 03-04-2015, 11:18 PM
  2. can't open picture attachment in text message
    By kdavidson100 in forum Ask a Question
    Last Post: 03-04-2015, 10:58 PM
  3. Play store and sign in issues
    Last Post: 07-18-2014, 11:45 PM
  4. My Device Is not listed in the How to root phone page Help!
    By Unregistered in forum Ask a Question
    Last Post: 07-18-2014, 10:41 PM
  5. Replies: 0
    Last Post: 07-18-2014, 08:56 PM
