Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By kwknott
    Default how to turn the shutter sound off?
    so i downloaded the app "Tasker" and did what i am supposed to. but the shutter sound for the camera still wont silent. can someone tell me specifically what i should do in the "Tasker" app? mine says "no active profiles" but i'm pretty sure my profile is active? idk... i just want the stupid sound to stop
  2. #2
    kwknott's Avatar
    Posts
    Carrier
    Backside... MiRaGe
    Default Re: how to turn the shutter sound off?
    The sounds are actually built into the app on the Elite. The only way we found to stop it was by actually modifying the apk to remove them.
    For this to work you must replace the camera app with the modified one which requures you to be rooted. Other than this there is no other method ye to silence sounds
    Hashtag over at Android Forums figured this out and modified the apk and posted it. If you are rooted you can download the modified camera app here http://androidforums.com/showthread.php?p=4795816 and replace your camera app
    Sent from my LG-VM696 using Tapatalk 2
    helloin321 likes this.
  3. #3
    curtis1973's Avatar
    King Of Pants
    Posts
    Carrier
    CM10/Sense
    one alternative method might be to try a seperate camera app from play store. many of them allow you to silence the shutter.
  1. How to disable the nofication sound for USB connection?
    By Rev2010 in forum Motorola Droid 2
    Last Post: 12-19-2011, 11:10 AM
  2. Is it possible to silence the shutter sound?
    By kalex in forum LG Optimus S
    Last Post: 02-05-2011, 10:41 PM
  3. How to pull the back cover off?
    By Baconator in forum T-Mobile Nexus S
    Last Post: 12-20-2010, 11:57 PM
  4. How to turn the volume down of button presses?
    By iPwn in forum Verizon Fascinate
    Last Post: 10-14-2010, 12:14 AM
  5. How To Turn The X Into A Multimedia Entertainment System?
    By miamifin33 in forum Motorola Droid X
    Last Post: 09-19-2010, 06:15 AM
