Help please! Wont boot after Beats Audio installer!
Hey guys, i rooted my VM696 the other day and everything was fine untill i donwnloaded the Beats audio installer. It asked me to reboot then its stuck at the LG loading screen.
I got into the stock recovery and tried to reset it but still nothing..
Is there anything else i can do? Thank you:'(
Re: Help please! Wont boot after Beats Audio installer!
You are going to have to restore your phone to stock. It looks like this link will get you there:
[Only registered and activated users can see links. Click Here To Register...]
Ive looked at it and tried it, cant get the file to even unzip says its broken or unsupported with winrar
man i cant even get passed the LG logo, i have tired everything
I had the same problem. What I did was boot into recovery and flashed a custom rom. You can also factory reset which should work
