Results 1 to 9 of 9
    Exclamation Optimus g pro Bricked !!! Help Need E980 original firmware
    SO... just got phone had it rooted and well wanted to try some rooted software...SIGH .. now phone is looping tring to boot ... i got everything i need to unbring by following step to unbrick old optimus g... just need to get the e980 firmware. I might just bring it back and have att give me another one only 2 days old but would like to do on my own. Any help would be great thanks !
  2. #2
    Darth Spock's Avatar
    Posts
    Global Posts
    5,723 Global Posts
    ROM
    Assassin 'Droid
    Default Re: Optimus g pro Bricked !!! Help Need E980 original firmware
    I'd strongly recommend not returning it to AT&T or to LG as any warranty will be instantly useless. Can you be more specific about where the loop initiates? Is this when you're attempting to boot into the bootloader or into recovery or is it when trying to start up regularly or both?
    ​Obvious statement: Why, I am an assassin 'droid, Master.
    May the Force Be With You
    Community Rules & Guidelines​
    (Formerly "NothingIsTrue")
    just stuck on lg sym and light just changes color i can get into download mode and get into the file using android commander ...this all started when i downloaded chainfire 3d sigh
    ok so did some test and after following direction from xda >>Having root access from recovery is a must to solve problems if you run into them (run "/system/lib/cf3d_uninstall.sh" as root to remove the driver and restore the old one)
    1. boot into jb recovery mode
    2. run "adb devices" - to make sure the phone drivers are ok (should output a long hex string and "device")
    3. run "adb shell" from command prompt
    4. in shell prompt "sh system/lib"
    5. still in shell "sh /cf3d_uninstall.sh"
    well i figure it out lol ...
    command adb devices
    and it booted ..
    did this 50 times not sure what i did but its unbricked lol hope no1 else runs into this ...do not download for optimus g pro
  5. #5
    05GT's Avatar
    Posts
    Global Posts
    187 Global Posts
    The factory tot is available on XDA.
    Sent from my LG-E980 using Tapatalk 2
    - 13.3 Retina MacBook Pro
    - AT&T LG G2 | AT&T LG Optimus G Pro
    - AT&T Samsung GS4 | AT&T Galaxy Note 3 | Samsung Galaxy Note 10.1 2014 | Samsung Galaxy Gear
    - AT&T Nokia 1520
    - T-Mobile Xperia Z1s
    - LG G Pad 8.3 GPe
    - 16GB Google Nexus 5 | 32GB Google Nexus 7 2013
    - 32GB iPad Air | 16GB iPad Mini Retina
  6. #6
    I can't find this firmware you speak of. I'm totally bricked, can get to homescreen after a factory reset from recovery, but then it reboots after 1 minute into a bootloop. A link would keep me from chucking my phone at my tv screen.
  7. #7
    Delete - double post
  8. #8
    I have a similar problem that you have, but caused the probably using poor judgement. I was deleting system apps and bloatware, but I went too far and noticed I could not get my settings anymore for my phone. I did backups of all the apps on titanium back up on my SD card, but don't know how to get it back on to the phone when it will not even boot up. Where did you get the following information? Can I do the same thing?
    Quote Originally Posted by Mike Tomasullo View Post
    command adb devices
    and it booted ..
  9. #9
    where can i find how to root this phone? ive searched everywhere! PLEASE help me thanks
  1. Galaxy Tab Might be bricked - Help Needed
    By scratch135 in forum Samsung Galaxy Tab
    Last Post: 11-07-2012, 10:11 PM
  2. Lg Optimus V *BRICK* HELP PLEASE
    By Saintkilla in forum Virgin Mobile Optimus V
    Last Post: 04-18-2011, 12:15 AM
  3. Phone pseudo bricked - really need some help (hopefully from thefredelement)
    By hgelpke in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-31-2011, 05:05 PM
  4. Optimus V maybe BRICKED... please help
    By Lindo694eva in forum Virgin Mobile Optimus V
    Last Post: 03-04-2011, 10:48 PM
  5. bricked phone, need help!!
    By itzjonjon69 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 11-17-2010, 07:04 AM
B
