Has anyone been able to get this to work?
I'm on the Family Plan that has 500mb of HotSpot before needing to pay. Every time I try and enable it I get a error.
I don't really need it, but I'd like it to be there just in case.
Thanks
Update 6/29/2013
I ended up having to root my phone to get it to work it took about 2 minutes (I never wanted to have to root).
I had called Tmobile and they were no help at all. Turns out its a stupid database setting and you need root access to modify the value from a 1 to a 0.
Update 7/4/2013
Guess I should have posted the links to do this.
[ROOT]Windows/Linux file to root all Firmwares(Should work on all versions) - xda-developers (how to root in like 2 minutes)
Wifi Tethering working ! !! - xda-developers (3rd post down screen shots and step by step to get hotspot working)
Thanks
Update 6/29/2013
Update 7/4/2013
