1. Matt Northnun's Avatar
    So like the title says, this is my first Android device so this could be a very simple fix that i am simply unaware of. I want to move the "apps" icon off the bottom row of apps, but the icon automatically goes back to the spot on the bottom row where it was before i tried to drag it somewhere else. Am i doing something wrong here? Thanks for any help
    07-23-2013 12:18 AM
  2. Mellimel22's Avatar
    The only way to permanently change it is to install another launcher like nova or apex.
    Sent from my T-mobile LG Escape using Tapatalk 2
    07-23-2013 12:26 AM
  3. w0ng's Avatar
    try remove it, usually it can.
    Sent from my SCH-I605 using Tapatalk 4 Beta
    07-23-2013 12:34 AM
  4. natehoy's Avatar
    When you select the "Apps" icon on the OGPro, the "Remove" area does not appear. You can move it to another slot on the bottom bar, but you can't move it onto the desktop, you can't remove it, and you can't make it part of a folder on the bottom bar (like you can with every other icon).
    LG has designed it so you must have that icon in your bottom bar if you want to use their default launcher, probably to keep people from deleting it or moving it out of sight and losing access to their app drawer (since unlike some other launchers the app drawer does not appear on the launcher menu and once you've deleted it there's no way back in).
    Not the wisest of design choices IMHO, but a minor quibble (also IMHO).
    07-23-2013 08:26 AM
  5. w0ng's Avatar
    well.. doenload other launcher from plsy store then, nova is my favourite.
    07-23-2013 10:32 PM
  6. hakimmmmm's Avatar
    try action launcher. Simple and best
    Sent from my One using Tapatalk 4 Beta
    07-23-2013 11:39 PM
  1. Do I have to factory reset every time I flash a rom?
    By Bryant Rawls in forum HTC One Rooting, ROMs & Hacks
    Last Post: 07-24-2013, 02:32 PM
  2. Too Many Apps Doing The Same Thing
    By harryhoudini66 in forum Samsung Galaxy S4
    Last Post: 07-23-2013, 12:53 AM
  3. my nexus 7 wont goes past the logo screen
    By John Boland in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-22-2013, 11:58 PM
  4. Rooting my HTC Sensation with my MacBook Pro
    By Juliet72 in forum Sensation Rooting, ROM's and Hacks
    Last Post: 07-22-2013, 11:43 PM
  5. How do I sort Twitter contacts in the Following tab?
    By ralvy in forum General Help and How To
    Last Post: 07-22-2013, 10:43 PM
