optimus g pro 5.5 inch how big realy then normal
Chinmay Panda
7
I am now confused between optimus g and g pro because of the screen size difference.
2. i want a device for my daily use.does it get comfertable on my daily use
3. do i need to take extra care of it?is it gets handy to every where
npaladin-2000
1,175
11
Re: 5.5 inch how big realy
Depends on how big your hands are. The pro is a largish phone. But the screen is great and so is the standby battery life.
Sent from my LG-E980 using Tapatalk 4
npaladin-2000
1,175
11
Faster processor, different button location, no SD card slot. Screen is smaller by 0.3 inches.
natehoy
2,667
71
Honestly, you'll have to hold one. That's the only way to know if it's going to be comfortable. It's a little smaller than the Galaxy Note series, same screen size but smaller bezel. Now that I'm used to it, I find even a 5" screen feels small. But different people are comfortable with different phone sizes.
As far as extra care, well, it is a larger screen and a narrow bezel, but few phones do well if they are dropped. A case is highly recommended.
ajarnfalang
203
Well. More than that because they have the android on screen buttons and that takes up even more screen. So in reality the G2 will be more like 4.9"-5.0".
Akshay
