limitbreak09
Re: Gps turns on during phone calls
Just a quick question about warranty, Ive never done it before so if you have are they goin to replace your fone for free or not?
Sent from my LG-E980 using AC Forums mobile app
I think I will go with the 3rd choice. If the GPS issue re appears. I will take advantage of my warranty and get a entirely different device. Although I will miss my LG Optimus G Pro.
