1. dinhcara's Avatar
    Hi,
    I have been getting only 20 hrs of battery and only 3 hours of screen on time. I have not used any processor intensive apps. Please check the images attached. Is this normal? I have bought it a week ago and I can get a replacement if the battery is defective. What do you think? Don't plan or rooting it.
    P.S: I have chosen ogp over n5 because of the extra battery, but ogp's battery is equally bad.
ID:	95685Click image for larger version.
ID:	95686Click image for larger version.
    12-07-2013 09:03 AM
  2. penningtonsm's Avatar
    Three hours of screen on time is what I was getting before I switched to the Zerolemon battery. Your stand by time us pretty good, but I don't think you're going to get more screen on time than that. At least I couldn't. And I tried all the battery saving tools out there.
    Sent from my LG-E980 using Tapatalk 4
    12-08-2013 06:16 AM
  3. dinhcara's Avatar
    So, this is normal screen on time? Is it? I am disappointed with the battery life, I had chosen OGP over N5 primarily because of the battery. I thought I could use this phone a smartphone was meant to be used, but I guess I was wrong.
    12-08-2013 10:04 AM
  4. Shelter7's Avatar
    Don`t be disappointed! As I could notice, he was at 10% capacity of its battery, it was normal to discharge in less than 2h, either it`s a stock or an external battery, such as that designed by Zerolemon. You can see its power, when it`s 100% charged
    02-24-2014 10:03 AM
  1. Replies: 21
    Last Post: 10-29-2014, 10:56 PM
  2. Samsung galaxy S3 battery drain
    By tfromero in forum Samsung Galaxy S3
    Last Post: 12-10-2013, 02:08 PM
  3. Good battery saver app for N4 with 4.4?
    By billdz in forum Google Nexus 4
    Last Post: 12-09-2013, 03:34 PM
  4. What is an easy way to backup my HTC One V before I root?
    By jayboiandroid in forum HTC One V
    Last Post: 12-08-2013, 01:46 PM
  5. loose battery cover?
    By cutlass528 in forum Samsung Galaxy S3 Mini
    Last Post: 12-07-2013, 11:42 PM
