Results 1 to 20 of 20
Like Tree4Likes
  • 1 Post By B. Diddy
  • 3 Post By Austin Hillman
    illyana66's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default LG Optimus G: Phone died and won't charge and turn back on. help?
    i have an lg optimus g
    i havent had this problem before
    my phone isnt even a year old yet.
    my phone died and shut off. now its not charging. ive tried charging it on my charger, other phone chargers, through the computer, a kindle charger, but nothing is working. the charging light isnt showing at all. ive just left it on the charger for now but nothing is happening...
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,012 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Phone died and wont charge and turn back on. help?
    Welcome to Android Central! Unfortunately, that doesn't sound good. It sounds like the battery might have failed, although it could also be an even worse problem with the motherboard. Your best bet is to take it to a cellphone repair shop, unless your phone is still under warranty, in which case you should contact LG.
    If you're adventurous, you could try to replace the battery yourself:
    UJ95x likes this.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,082 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by illyana66 View Post
    Welcome to the forums.
    Have you tried a different cable as well?
  4. #4
    adobian's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have you tried swapping out the battery ?
  5. #5
    Nandor Csonka's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: LG Optimus G: Phone died and won't charge and turn back on. help?
    I have an LG Optimus G Pro and it is almost a year old. I was having the same problems with the charge so I bought a new replacement battery for it. I have been putting the phone on 3 or 4 different chargers and I still can't get the phone to charge any more then 40%. Most of the time I am losing charge % even while it is on the charger. Do you think it is a Hardware issue?
  6. #6
    Austin Hillman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: SOLVED! LG Optimus G: Phone died and won't charge and turn back on. help?
    I'm aware that this is an old thread, but today I faced the same issue after coming across my old LG phone, and after searching, found this thread.
    BUT, I have a solution to this issue! All I had to do was remove the battery from the phone and plug the charger into the phone with the battery still removed. Once I did that, my phone instantly responded and although it wasn't holding a charge (the battery was still removed) The charging indication did light up and blink. I unplugged the charger, inserted the battery again, plugged the charger back into the phone, and what do ya know, it started charging right away and successfully powered on after just a few minutes of charging!
    Again, I know this is an old thread, but I figured I would post the solution for those like me who may come searching months or even years down the road (like myself) for a fix to their issue.
  7. #7
    Arieas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just wanted to say thanks for posting. Had this happen with my LG G4 815 this morning, and this post saved me a great deal of frustration.
  8. #8
    Noah Moquin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same with me, but the light will show
  9. #9
    Naranjadel Oeste's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    To Austin Hillman: Oh my goodness! This immediately worked for me! I came here because I just experienced the same exact problem, and you really did have the solution. Thanks so much for sharing!
  10. #10
    AnnMMoz's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried both my kindle charger and the one that came with the phone, took out the battery, put in the battery, nothing is happening when I try just having the phone plugged in with no battery either. saw a thread suggesting maybe the phone or battery got wet but I don't seem to have a bit of paper in my phone, much less one that turned purple or pink. Had the phone for about 4 years, with no problems until today when it just didn't come on. (died in it's sleep? it was sitting quietly on my desk, didn't fall, didn't get wet...) ?
  11. #11
    anon(9786162)'s Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Naranjadel Oeste View Post
    Worked for me too. thx Austin!
  12. #12
    Lisa Taylor5's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OMG..Thank you so much! I had my phone plugged up to at least 4 different chargers for my phone and tried my car charger and nothing worked. I tried your method and INSTANTLY it started charging! Thank you for your solution!!
  13. #13
    googooleboo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So glad that I found this! I just thought I had accidentally let my battery run down, but nothing was happening even a few hours after charging (and knowing that my charger worked). I did what you said and it came back on with my batter 100% charged! THANK YOU!
  14. #14
    Tiffany Lynn C's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: LG Optimus G: Phone died and won't charge and turn back on. help?
    This post was SO helpful!! If you too are experiencing bad charging issues like the story above you should try this way! It worked for my phone when i accidently let it die completely and the next morning it was not charging. Found this post , tried it and its charging !
  15. #15
    Pips Herring's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    THANKYOU THANKYOU. Nothing was working for me and I was about to give up on the phone when I came across this! Thank you so much!!!
  16. #16
    K_Love22's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Austin Hillman View Post
    You sir, are a life saver!! Lol. I've been having this problem with my phone & came across this thread while searching for a solution, and I'm so glad I did. What you suggested totally worked right away! I'm just so excited and can't believe it actually worked. Thank you
  17. #17
    Kathycole75's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks. ...this was a life saver today with my daughter's phone. THANK YOU!!!! The phone came on instantly after doing the suggestion you posted.
  18. #18
    teresalynn209's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh my gosh...thank you thank you thank you..i panicked and almost drove all the way to town to buy a new phone...i did this and it worked. . .wow..thank you so much
  19. #19
    juggernaunt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well taking the battery out made it work again
  20. #20
    prasanth crajan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks a lot , it really helped.
  1. I got an Android, but want to go back to the iPhone. Why is this?
    By xxventanaxx in forum General News & Discussion
    Last Post: 04-04-2014, 08:44 PM
  2. Galaxy S4: Phone no longer displays photos in my gallery
    By Markersk in forum AT&T Samsung Galaxy S4
    Last Post: 02-13-2014, 11:35 AM
  3. HELP. i need to get pictures/videos off broken galaxy s4
    By lynzrene in forum Samsung Galaxy S4
    Last Post: 02-08-2014, 11:26 AM
  4. Tethering speed and mobile internet
    By tv658 in forum General Help and How To
    Last Post: 02-08-2014, 12:02 AM
  5. Replies: 2
    Last Post: 02-07-2014, 10:45 PM
