1. Brad Steele's Avatar
    My problem is, when I leave wifi on and go out of range then come back into range the quick remote appears on the lock screen. The quick remote is toggled to off on the notification drop down, and also the option for wifi is turned off under quick remote options. So to get it off the only option I have is to launch quick remote, go into options, select turn on when in wifi range, add my home wifi network, delete the home network then uncheck turn on when in wifi network range. Please God tell me it's something simple to stop this from happening.
    OGpro_2_AC
    02-10-2014 01:27 AM
  2. fireguy2002's Avatar
    The only other thing I would suggest is, when you see it on the lock screen, hit the home button and see if it turns off.
    gog8rs#WN likes this.
    02-14-2014 12:43 AM
  3. Brad Steele's Avatar
    Six months and I just tried it. Home button acts as a toggle for Qremote on lock screen. I feel like a total n00b.
    This forum is in unacceptable condition, UNACCEPTABLE!!!!
    12YRS DUNGEON, EVERYONE, NO TRIAL.
    05-31-2014 12:52 PM
  4. Xavier Delgado's Avatar
    Not happening to me..
    I just found awk that no resize option is available wwith quick remote now.
    06-02-2014 05:06 PM
  5. Brad Steele's Avatar
    Moderator please delete this thread as issue has been resolved. Thank you.
    Lg0Gpro_2_AC
    08-22-2014 02:50 PM
  1. All primary shortcut keys disappeared on Galaxy S4
    By hkj2014 in forum Samsung Galaxy S4
    Last Post: 12-11-2015, 05:02 PM
  2. Updating Market to Google Play on HTC EVO 4G troubles
    By Jabberwockxeno in forum HTC EVO 4G
    Last Post: 05-02-2014, 04:09 PM
  3. getting note 3 does it come with ear bubs
    By zaydabarber in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-16-2014, 08:55 AM
  4. Accessing your notifications on the lockscreen!
    By Gator352 in forum Samsung Galaxy Note 3
    Last Post: 02-13-2014, 03:45 AM
  5. AT&T Galaxy S4 not staying on WiFi since 4.3
    By wetermommy in forum AT&T Samsung Galaxy S4
    Last Post: 02-11-2014, 08:16 PM
