1. shaleen55's Avatar
    Hello All
    I recently purchased the LG Optimus G Pro which came with just one microUSB to USB cable for using to transfer data from the PC to the G Pro as well as to charge the G Pro with its wall charger. I'd prefer to dedicate this cable for only the wall charger purposes.
    So, for transferring data between my PC to the G Pro, can I use the microUSB to USB cable which came with my Sony Reader PRS-650 (and which I use to sideload ebooks onto my Sony Reader) , or am I likely to cause problems ?
    My question basically is : Are these microUSB to USB cables universal for all devices or are they specific to the device they come with ?
    I'll appreciate any inputs.
    Shaleen
    02-12-2014 03:02 AM
  2. mrsmumbles's Avatar
    I think the charging cables are a little different from the data cables you'd use with a computer. But it wouldn't hurt (probably) to try it and see, any more than using the OEM cable.
    Sent from my Nexus 5 using Tapatalk 2
    02-12-2014 03:11 AM
  3. shaleen55's Avatar
    For charging the G Pro, you connect the microUSB end to the G Pro and the USB end to the wall charger.
    For connecting PC with G Pro, you connect the microUSB end to the G Pro and the USB end to the PC USB-port.
    This is exactly the configuration I have for my Sony Reader PRS-650 too and it came with 2 microUSBtoUSB cables- one for use with the charger and the other for using with the PC and both these cables were identical. Which is why I am curious to find out if these microUSBtoUSB cables are interchangeable or specific to the device they come with. Maybe someone knowlegeable about this can help us.
    02-12-2014 04:26 AM
  4. SKDroid1234's Avatar
    What is the point in dedicating a cable to the wall charger? It makes no sense. Use the same to connect to PC. Besides I have used other cables (Samsung, vendor less) to connect the LG GPro to the PC and charger. No issues. It is just a cable guys.
    Sent from my N550JV using Tapatalk
    05-26-2014 03:45 PM
  1. LG G2 Screen Protector
    By JAG21979 in forum LG G2
    Last Post: 02-18-2014, 08:45 PM
  2. LG Optimus F3 (VM) - WiFi connectivity
    By sinadone in forum LG Optimus Series
    Last Post: 02-13-2014, 02:08 AM
  3. lg g2 widgets
    By bridawg8 in forum Verizon LG G2
    Last Post: 02-12-2014, 01:08 PM
  4. Lg g2 cm 11
    By Nasko in forum LG G2
    Last Post: 02-12-2014, 01:39 AM
  5. Dinosaurs 3D Pro live wallpaper
    By Ruslan Sokolovsky in forum Wallpapers, Ringtones, and Themes
    Last Post: 02-12-2014, 01:29 AM
