1. shaleen55's Avatar
    Hello All
    I am considering a 32GB microSD card for my LG Optimus G Pro E988 (16gb internal mem).
    I'm considering the 32GB Samsung Plus class 10 UHS-1 (10 year warranty): Model MB-MPBGC. No adapter.
    Anyone used it with the G Pro ? Does it give good speeds ? anything I need to be aware of ? Do I need to register these cards on the Samsung website for the warranty to be applicable ?
    I'm a novice where this is concerned and I don't want my data lost due to cards failing. I rely on reliability (literally) where cards are concerned. Like Sandisk Ultra seems to give better speeds but there are too many fakes going around.
    Thanks for all inputs.
    Shaleen
    03-03-2014 06:09 AM
  2. ematija's Avatar
    Go to a store and you will have warranty and will not get fakes. There are samsung fakes too. Also, i have SanDisk. 64gb. No problem at all. In the manual it's stated to use microsd and sdhc. Sdxc was not mentioned, but i have sdxc and it works just fine. If you want more storage, why not 64gb? It's not that much more expensive, but you are using phone's maximum.
    LG OGP E986 & tapatalk
    03-03-2014 06:18 AM
  3. shaleen55's Avatar
    Hi ematija,
    Thanks for the prompt reply. I'll look up the 64GB options as you suggested.
    As I understand you are using Sandisk Ultra SDXC class 10 64GB (30MB/s). Do you use this sdxc card with its sdhc-adapter for the G Pro ?
    Do you have any idea about the practical speed differences between the Sandisk Ultra cards and the Samsung Plus cards ?
    Shaleen
    03-04-2014 02:47 AM
  4. SKDroid1234's Avatar
    I have been using 64GB Sandisk SDXC card without any issues with LG OGP E988. I have even installed custom ROMs and the SD card has been accessible with them too. I also have all my media files on the SD card and it works fine.
    Sent from my N550JV using Tapatalk
    05-26-2014 03:40 PM
  1. LG Optimus G Pro: bootloader - how to unlock?
    By dkr627 in forum LG Optimus G Pro
    Last Post: 05-26-2014, 03:54 PM
  2. Repeat Data Roaming Notifications - T-Mobile LG G2
    By WaarrEagle in forum T-Mobile LG G2
    Last Post: 05-02-2014, 03:42 AM
  3. Note 3 vs LG G2
    By bboysmax in forum Samsung Galaxy Note 3
    Last Post: 03-05-2014, 04:54 PM
  4. LG G2, Microphone really loud?
    By endrien in forum LG G2
    Last Post: 03-02-2014, 07:01 PM
  5. Galaxy 3 7" Moving apps to SD card
    By Lizzrd in forum Samsung Galaxy Tab 7-inch
    Last Post: 03-02-2014, 04:05 PM
