Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Paul627g
  • 1 Post By John Loesch
  • 1 Post By frope01
  • 1 Post By AzAssassin
    Default LG Optimus G Pro: Cracked screen?
    Has anyone replaced the glass on their G Pro? Where did you get it? How difficult was it? N5 is cool but it's not my G Pro. Maybe I'll just wait for the G3.
    Sent from my Nexus 5 using Tapatalk
  2. #2
    Default Re: LG Optimus G Pro: Cracked screen?
    I never like to tell anyone to search but that is exactly what I've resorted to when I fixed the displays on my devices. If something exists there will be some YouTube videos and accompanying instructions/links to ordering parts.
    I just know with the use of glued displays and other advancements to " seal " up devices today they are getting harder to replace and do it without issues down the road.
    frope01 likes this.
  3. #3
    I purchased a replacement screen from a vendor on eBay and followed the excellent guide by repairsuniverse. Their instructions were clear and I have had no issues with the replacement save for this past weekend when the digitizer appeared to go nuts by touching things by itself. It turned out to be something with the AT&T screen protector, as it stopped when I removed it. No other issues since.
    I would not recommend doing this unless you have some experience working with small screws and miniature electronics, my experience is with model trains and installing DCC circuit boards in them, so I knew the precautions to take.
    Like a modeling friend of mine says, you too can achieve the same results I do so long as you are willing to follow the provided instructions. It wasn't that difficult, and I'd do it again if I had to.
    frope01 likes this.
    I ordered the screen for $30, and repair kit from fixez who I saw on YouTube. I'm looking forward to fixing it myself.
    John Loesch likes this.
    Update. I almost forgot. The repair was easier than I anticipated. I watched three videos but the one from fixez was best. It showed replacement with the least amount of parts removed. I ordered a kit which was supposed to come with adhesive strips but did not. A very nice tech at a local screen repair shop gave me some adhesive which saved the day.
    Cost of the project was less than $55 and actual time spent was less than 30 min. The repair shop charges $200.
    Sent from Frope's G Pro.
  6. #6
    I realize it's probably a longshot to get a reply in this thread, seeing at as it's almost been a year since the last post, but I recently got my daughter a used LG G Pro (E980) and it has a cracked screen, so I'm really interested in possibly buying a replacement LCD/Screen and trying to install it myself. Could you guys possibly share some specific details about which exact sSreen/LCD replacement kit you bought and which site/seller you bought it from?
    I was also really curious to find out if the replacement screen held up and if the phone worked properly for a long time after doing a self-install?
    If someone would respond these questions, I would really appreciate it. Thanks in advance to anyone who replies!
    Quote Originally Posted by AzAssassin View Post
    Here are links to the video I used and the site I ordered from.
    I only got the touch screen replacement. I recommend getting the LCD + touch screen together. It went on easy and looked beautiful but I had a small touch responsiveness issue that I could have avoided by getting the LCD + touch screen. I also got a toolkit from them. The 16 piece kit I believe.
    http://www.fixez.com/store/lg/lg-optimus-g-pro
    Hope this helps. It's a great underrated phone.
    Sent from my sweet G3.
    ♻Positivity!
    Oh yeah, it still works and I still use the phone at home sometimes.
  8. #8
    Quote Originally Posted by frope01 View Post
    ♻Positivity!
    Thank you very much for the response and for the detailed information. I sincerely appreciate it! I'm about to get ready for work, so I don't have time to check that out and try to purchase it right now, but I definitely plan on doing so after work. If I end up ordering it and trying to install the screen myself, I will be sure to come back here and post an update with my experience and the results.
    Thanks again for taking the time to reply and to share the links and your experience with me! I really appreciate it.
    frope01 likes this.
  1. On screen vs Off Screen Buttons
    By JR A in forum General News & Discussion
    Last Post: 10-11-2015, 10:43 AM
  2. Droid Razr M Home Screen Error w/ 4.4.2 update
    By StephisDangerout in forum Android 4.4 KitKat
    Last Post: 05-30-2014, 04:07 PM
  3. Screen capture issue
    By Luis Velasquez in forum Samsung Galaxy S5
    Last Post: 05-22-2014, 04:40 AM
  4. Recent app screen
    By nori_nori in forum Samsung Galaxy S3
    Last Post: 05-22-2014, 03:50 AM
  5. LG G2: help with external battery
    By Gavvykinz in forum LG G2
    Last Post: 05-22-2014, 02:20 AM
