01-27-2015 12:49 PM
75 123
tools
  1. PAC757's Avatar
    I Wanted to start a thread to see if anyone that has the official AT&T OTA update to 4.4.2 KitKat has any issues after the update, not getting the update downloaded or installed, but just any issues with the LG Optimus G Pro AFTER installing the update. I have been running it for 2 days now and have only seen the following issues:
    1) The automatic brightness is way more conservative than it was before, at night I have to turn off auto brightness as it is to dim. ( maybe this is where they say better battery life in the channel change log)
    2) I have been using the phone in the same places as usual for the past 2 days, my signal strength indicator is about 2 bars lower than it has been for the past 5 months. ( It could just be a coincidence, but it is definitely lower)
    3) As far as battery life, other than the first day that I updated to KitKat, it have been the same, no worst, no better. Which is good because the battery life has always been more than acceptable.
    Anyone else notice any changes or issues since updating you LG OG Pro?
    05-31-2014 02:51 PM
  2. marcus0263's Avatar
    Big one, lost permissions to external microSD card
    Sent from my Phone w/Tapatalk Pro
    frope01 likes this.
    05-31-2014 07:42 PM
  3. limitbreak09's Avatar
    No wayy??
    05-31-2014 08:07 PM
  4. Billinok's Avatar
    Definitely the auto brightness is dimmer on auto and it fluctuates by getting dimmer then brightens a little. Just got the update, so if any other problems will post.
    05-31-2014 08:21 PM
  5. Billinok's Avatar
    I'm not liking that
    frope01 likes this.
    05-31-2014 11:02 PM
  6. limitbreak09's Avatar
    Battery life seems normal to me, but I notice a huge improvement in my WiFi signal strentgh. Before the update I usually have 2 bars, but now I'm getting 3-4 easily. Haven't found any bugs yet.
    06-01-2014 06:48 AM
  7. limitbreak09's Avatar
    OK found one... Where the hell is my screen time on?? I had it earlier then I changed the battery and turn it on, now its gone!
    Attached Thumbnails AT&T Post KitKat Update problems / Issues Anyone?-screenshot_2014-06-01-07-55-33.jpg
    06-01-2014 06:57 AM
  8. Nelimungous's Avatar
    +1 on the automatic brightness issue. In low light the auto setting way tooo low.
    06-01-2014 10:50 AM
  9. Billinok's Avatar
    This is mine
    Attached Thumbnails AT&T Post KitKat Update problems / Issues Anyone?-22440.jpg
    06-01-2014 02:17 PM
  10. Xavier Delgado's Avatar
    Before my battery would drain pretty quick when using mobile data. That issue has been fixed.
    I feel using more mobile data now and battery isn't draining that much!
    06-01-2014 05:58 PM
  11. marcus0263's Avatar
    I'm not liking that
    Yep, its by design from Google. LG should have fixed this before they pushed it out.
    Only way around this is to root, pissed me off big time. Of course ATT support says reset the phone... idiots reading off a script.
    frope01 likes this.
    06-02-2014 08:16 PM
  12. marcus0263's Avatar
    Yep, bad enough I had to turn it off
    06-03-2014 12:05 AM
  13. PAC757's Avatar
    I really think they adjusted the auto brightness to, seemingly, up the battery life I left mine on auto, for the better part of 37.5 hours, turned it off when I absolutely had to to see the screen better. I never had a problem with the battery on this phone, heavy use and always made it 19 hours or so. This past day and a half, I used the phone about the same and wanted to see how long it would last, well 37.5 hours, screen on time about 4 hours. So that is the only thing I can think that extended my battery time, but will definitely not be leaving it on auto 100% of the time, battery life on this phone has been good either way, just use it the way you need it.
    06-03-2014 08:24 AM
  14. Xavier Delgado's Avatar
    Can't play any AVI. videos. I had to install a 3rd party player and codec. Woaaaaaah so frustrated!
    06-03-2014 08:51 PM
  15. Wayne Kerr's Avatar
    Good day, all! This is my first post here and I registered just to respond to this thread.
    I did my update this morning and since then I've not been able to keep my bluetooth headset (Motorola HX550) paired with my phone. Before the update it would automatically pair as soon as I turned the device on, since the update I have to pair the device every time.
    Any suggestions?
    06-04-2014 03:33 AM
  16. rizzle00's Avatar
    damn i wish i could gt 19hrs.. **** i cnt make it thur a 10hr work day with m phone being in airplane mode 8 out of the 10hrs.. only to talk or text during breaks..
    - - - Updated - - -
    06-04-2014 01:28 PM
  17. CycloneSpoiler's Avatar
    My Link S slimport no longer pushes to tv.
    06-05-2014 03:35 PM
  18. nhraamy's Avatar
    I hate the new update. Picture thrown into a new file, I cant post pics to a different app, address bar always shown when online, havent noticed anything about battery life because the battery always sucks on phones, they changed the keyboard. Just a mess. Just leave it as it is. You dont have to change it, just to justify having employees.
    06-05-2014 04:58 PM
  19. CycloneSpoiler's Avatar
    Slimport seems to be working again. User error. Loose hdmi cable.
    06-05-2014 06:36 PM
  20. Xenon89's Avatar
    THE BATTERY LIFE ON MY PHONE HAS DROPPED SIGNIFICANTLY!! I DONT KNOW WHAT TO DO NOW. I loved this phone for everything, especially the battery life. Now the battery life drains to 50% in like 4 hours!! Before I could go the whole day and more without charging!!
    06-06-2014 10:17 AM
  21. limitbreak09's Avatar
    Happened to me too!! 2 days after the update I was ssooo happy bc battery life got better like I was getting 6 hrs screen on with moderate to heavy use... But since yesterday Im only averaging 4 hours now.. and I noticed that my android Os is actin up crazy and consuming most of my battery.. idk whay they did this past few days,
    Attached Thumbnails AT&T Post KitKat Update problems / Issues Anyone?-screenshot_2014-06-06-15-19-41.jpg   AT&T Post KitKat Update problems / Issues Anyone?-screenshot_2014-06-06-11-30-30.jpg
    06-06-2014 02:24 PM
  22. marcus0263's Avatar
    Due to the updates removing write access to the MicroSD I ended up rooting my phone. So I thought I'd remove CarrerIQ also, well no longer problems with my GPS, battery life has increased and my phone is faster.
    06-06-2014 08:22 PM
  23. ConvertedGal's Avatar
    My battery life has gone way down after the update, I updated yesterday. For example: I charged it to 100% and used it like I normally do and it drained down to 90% in about 20 minutes. In the time it has taken me to type this it has gone down 2%. I loved the long-lasting battery on this phone, but not liking what the update has done to it.
    Sent from my LG-E980 using AC Forums mobile app
    rizzle00 likes this.
    06-06-2014 11:25 PM
  24. limitbreak09's Avatar
    Ok this is really weird... im only losing significant amount of juice when im on airplane mode..
    06-07-2014 10:52 AM
  25. S Smith4's Avatar
    06-07-2014 10:15 PM
75 123
  1. another new issue
    By geoffwhite18 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-11-2014, 07:02 PM
  2. AT&T KitKat update
    By atilt in forum AT&T HTC One
    Last Post: 05-31-2014, 05:22 PM
  3. Skype problem
    By marios1441 in forum General News & Discussion
    Last Post: 05-31-2014, 02:21 PM
  4. improved stability update?
    By Harshuvinod in forum Samsung Galaxy Note 3
    Last Post: 05-31-2014, 01:38 PM
