1. Larry Bennett's Avatar
    It won't play MP3s from my dropbox on the phone.
    What can i do?
    07-28-2014 10:05 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Did it ever work before? Are you trying to play the MP3 directly from the web, or are you downloading the MP3 to your phone first before trying to play it?
    07-28-2014 10:15 PM
  3. Muhun's Avatar
    Please help me out here. This is happening for second time...in just a year. My lg screen goes blank when I make calls and I'm unable to end the call. The only solution is to take out the battery and put back in. What's the solution for this..Thank you
    07-31-2014 01:31 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! In general, try to create a new thread if you are asking a question separate from the original poster's question.
    What phone do you have? Also an LG Optimus G Pro? Is the screen going blank when you hold the phone up to your ear, and then not turning back on after removing the phone from your ear? That could be a proximity sensor problem--make sure you don't have a dirty screen protector or a case that might be blocking the sensor (which is usually near the front facing camera). When the screen blanks out, can you still talk to the other person on the phone? What about when the other person hangs up--does the screen turn back on?
    07-31-2014 05:37 PM
  1. Note 3 AT&T WiFi problems
    By Bdrago86 in forum AT&T Samsung Galaxy Note 3
    Last Post: 08-28-2014, 10:53 AM
  2. YouTube problems on Verizon
    By mhans311 in forum Verizon
    Last Post: 08-02-2014, 05:48 PM
  3. LG G3 pic/video resizing tool
    By pizzano in forum LG G3
    Last Post: 07-29-2014, 01:28 AM
  4. Authentication Problem
    Last Post: 07-28-2014, 10:28 PM
