1. Nguyenning's Avatar
    I've gotten Camera Zoom FX, disables camera shutter... yet the sound is still there.
    I even put the phone in silent mode, yet the shutter sound is still there.
    Is it like the GS3 where muting the shutter isn't possible?
    11-19-2012 01:05 AM
  2. piizzadude's Avatar
    It is illegal in a ton of places to not have the shutter sound. This is to prevent 'candid' photos.
    Sent from my X-Band Modem... TY Genesis
    11-19-2012 01:16 AM
  3. Nguyenning's Avatar
    that may be the case in Japan and where upskirt pictures are all over the place... but what about taking pictures at a ceremony/somewhere quiet? Lame
    11-19-2012 01:18 AM
  4. ColonelTravis's Avatar
    Read on XDA that if you root the phone you can possibly do this:
    1.) Edit build.prop and set the camera sound value to =0
    2.) Find the "camera_click.ogg" file and delete it.
    Have not rooted my phone, waiting a bit to see what happens with other people. Other people are starting to root with few problems. But I'm still gonna wait because I've read of small problems.
    11-19-2012 01:58 AM
  5. piizzadude's Avatar
    Yes you can root the phone and get rid of it.
    No it is not just Japan, many states here in the US have that law. What you think we outsource pervs too?
    megamaster5 likes this.
    11-19-2012 02:46 AM
  6. bobby james's Avatar
    In the actual camera app, press the settings icon, scroll down and press shutter sound, there's 4 different tones and an off setting.
    11-19-2012 11:37 AM
  7. ens04's Avatar
    My phone doesnt have an off setting but it does have the 4 different tones.
    Is there any way for the off setting to show up? because I dont see it.
    11-19-2012 02:52 PM
  8. piizzadude's Avatar
    Not sure what phone or version of android the other guy is on, but it is not there. You cannot turn it off. Period. End finish done. If you want it gone, root and delete the tone
    11-19-2012 06:19 PM
  9. bobby james's Avatar
    I'm on the AT&T version. Not rooted. It's in the settings in the camera app. Also, having the phone on silent will also silence the shutter sound.
    11-20-2012 03:18 AM
  10. Nguyenning's Avatar
    weird... maybe it's just the Sprint version that doesn't allow silencing?
    11-20-2012 01:32 PM
  11. JSchoey's Avatar
    I have the Sprint version and my phone is rooted is well; I can't silence the shutter sound. Definitely could be a Sprint only issue.
    11-20-2012 03:10 PM
  12. piizzadude's Avatar
    My Verizon doesn't either... Until I go to Aosp.
    11-20-2012 03:28 PM
  13. Mramos860's Avatar
    I Have The ATT Model Too And I Have The Option To Shut It Off In The Camera Settings.
    11-20-2012 03:55 PM
  14. ColonelTravis's Avatar
    What happens if you plug headphones in?
    Still clicks.
    11-20-2012 04:20 PM
  15. turtle3#AC's Avatar
    Here's how to silence it on the stock Sprint version:
    Difficulty level: 2/10
    1. Root your phone
    2. Using your favorite Root Explorer open /system/media/audio/ui and rename camera_click.ogg to camera_click.old (ironically, on the LG phone this is not the audio file used by the stock camera, but if you don't delete this file other cameras like CameraZoom will have a shutter sound)
    3. In /system open build.prop. Make a backup before editing. About 2/3 of the way down under the group heading "ADDITIONAL_BUILD_PROPERTIES" is one line that reads "ro.camera.sound.forced=1" Change the "1" to "0". Save the file. Reboot your phone
    After doing this, when the phone is on silent there is no shutter sound. If you want a silent shutter when the ringer is on, go to System-Sound-Volumes and make the "Touch feedback & System" volume zero.
    Whoala...silent camera.
    unknown2me likes this.
    11-23-2012 10:22 PM
  16. Nguyenning's Avatar
    yeah step 1 there is the killer haha (for those of us who don't want to root)
    So, I'd give it a little higher than 2/10
    11-24-2012 02:01 PM
  17. turtle3#AC's Avatar
    Hhhmmm...well, rooting this phone is easier than I've ever seen. Takes less than 1 min once the drivers are installed. It's a 2/10 skill-level root for sure. Just follow the instructions in the sticky at the top of this forum.
    11-24-2012 11:05 PM
  18. Nikoleelee's Avatar
    What worked for me is putting Camera Zoom FX on Burst Mode and it will solve the shutter sound. No Rooting Required.
    Little Darwin likes this.
    02-09-2013 03:21 PM
  19. sk1win's Avatar
    This is clutch. You can set the burst to 1 as well so it really isn't a burst but the shutter is silent. Thanks.
    02-11-2013 12:06 PM
  20. Umang Anand's Avatar
    Hello ,
    You can temporarily put the phone on mute by using the Android Notifications Bar and then clik the photo at any resolution.
    There will be no shutter sound. This alternative can be used as a quick step for taking silent photos.
    Do remember to turn the phone sound on from notifications bar.
    cheers,
    Umang
    01-20-2014 01:21 AM
  21. Michael Freeman4's Avatar
    Why do you make this reply? Someone asked how to 'silence' the camera click, pure and simple. Do you know how to do it? No? - Then no one wants to listen to some amateur lawyer sprouting off on here about the legalities in different parts of the world do they? So do you know the answer or not? Obviously a 'not' so shut up about the other stuff! Your comments can come in the shape and form of being called as a witness I guess?!
    M
    06-09-2014 12:23 AM
  1. Can you silence the camera click sound?
    By PaulQ in forum Samsung Galaxy S3
    Last Post: 08-01-2013, 02:32 PM
  2. No Hi-Res Photos in People App - Not even with Exchange 2010
    By AdamHLG in forum Verizon Galaxy Nexus
    Last Post: 02-08-2013, 08:29 AM
  3. Can I wipe the memory of a phone with a broken display?
    By Slusho64 in forum General Help and How To
    Last Post: 04-21-2012, 11:45 PM
  4. I found a solution to the phone sync not working with computer
    By makris0000 in forum Samsung Transform
    Last Post: 05-24-2011, 12:03 AM
  5. Is it possible to silence the shutter sound?
    By kalex in forum LG Optimus S
    Last Post: 02-05-2011, 09:41 PM
