DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By Kiserai
    Default Android OS battery use???
    Android OS is consuming the vast majority of my battery life on this phone, which seems unusual given all of my other android devices the screen would usually be in first by a long shot.
    Battery is currently down to 30%, came off the charger at 7AM est. Moderate use, just email and web browsing, no video use. What are you guys seeing?
    I'm currently seeing Android OS using 46% vs Screen using 17%.
  2. #2
    cole2kb's Avatar
    Retired Moderator
    Posts
    Global Posts
    4,017 Global Posts
    ROM
    Stock
    Default Re: Android OS battery use???
    Check your sync settings. Settings / Accounts and tap your Google account, uncheck anything you don't need or just turn it off completely.
    Sent from my Motorola RAZR MAXX using Tapatalk 2
  3. #3
    Seems a lot of people are having this same issue with Android OS using up the majority of the battery. I went and unchecked a bunch of stuff per cole2kb's recommendation above. Hope it's something as simple as that!
    I just did the same, I guess we'll see
  5. #5
    I Dont see how that could be it when I leave my sync off all day. And for the vast majority of the day, I am in an area with no service and I leave airplane mode on. But yet I still have this.
    Attached Thumbnails Attached Thumbnails Android OS battery use???-screenshot_2012-11-27-18-46-01.png
  6. #6
    The DragonTJH's Avatar
    Posts
    ROM
    Stock
    I have similar numbers on mine, some folks over at XDA are guessing it's a software bug that's causing the keep awake time to be far too high. I can at least confirm that the awake time was equal to my time on battery. That just seems wrong, so I tend to agree with the techies over there.
    I did a factory reset, drained the battery and recharged to full while turned off and that seems to help with battery life a little. I would try that and wait to see if the devs can come up with a fix.
    Update time, unchecked synch. Removed from charger at 6:30a, streamed 25 minutes of a podcast w Bluetooth on the way to work, very light use since then and I'm down to 63%. Android OS is showing 49% use while screen is showing 20%. The odd Inge is my screen time on is only 52 minutes yet keep awake time for the CPU is 2 hours 6 minutes. Anyone have any ideas?
  8. #8
    Kiserai's Avatar
    Posts
    ROM
    The Base .5
    Quote Originally Posted by darkborne View Post
    Try the fix here:
    If you're on the AT&T version this might help you. Worked for me.
    jelong likes this.
  9. #9
    Quote Originally Posted by Kiserai View Post
    Try the fix here:
    Just tried this. I have a very long busy day tomorrow so I will post a screen shot before it dies to compare.
  10. #10
    Kiserai's Avatar
    Posts
    ROM
    The Base .5
    Just a heads up, it will still show Android OS as your top battery sucker. For me it's still around 45-50% of total battery use, but my battery life is doing very well regardless. As you can see in the pics, almost 20 hours on battery and still over 50%. Most of my day was on wifi, and I wasn't playing around on my phone all day, but at least now it's going into a deep sleep when it's in my pocket like it's supposed to.
    I should also point out that this is with Eco Mode OFF, all accounts set to auto sync, all location services and GPS are on, and I'm rooted and unlocked running The Base v0.5.
  11. Thread Author  Thread Author    #11
    I'm on a Sprint OG, and getting absolutely nowhere near the battery life you're getting. I've been on wifi since 8am est, moderate use and I'm already down to 55%
  12. #12
    Yea i am on sprint also and I tried the fix listed above and it helps but not a lot. I don't get any where near 20 hours on a single charge with data off, wifi off, auto sync off, power saver on, eco mode on, gps, bluetooth, and nfc all off. I hope an update fixes this issue, whatever it is.
  13. #13
    My O.G. for ATT is doing the same thing. I have had light use all morning and went from 100% at 9am to 45% at 1 pm and it shows that the android o.s at 61% and my display set to 50% has comsumed just 19% of battery. This really concerns me I wish LG would patch this
  14. #14
    It appears that LG has decided to write their own battery use app, forgoing the standard android one. This seems to be happening more and more with different vendors.
    I just got my lgog yesterday, so am still experimenting, however suffice it to say that lg's implementation of the battery use app is not very good.
    I've attached two screenshots from GSam battery monitor (yes, I am the author) compared to the LG one. GSam names the android os as kernel, but notice the huge difference.
    Not to toot my own horn, but in this case, GSam has it right
    Sent from my LG-LS970 using Android Central Forums
    Attached Thumbnails Attached Thumbnails Android OS battery use???-uploadfromtaptalk1355120225374.jpg   Android OS battery use???-uploadfromtaptalk1355120248703.jpg   Android OS battery use???-uploadfromtaptalk1355120261641.jpg
  15. Thread Author  Thread Author    #15
    I'm going to try a factory reset and see what happens. I dropped 60% with mid to light use today in 4 hours, I love this phone, but the battery life is getting obnoxious.
  16. #16
    pounder001's Avatar
    Posts
    Global Posts
    799 Global Posts
    ROM
    Stock
    Just got my AT&T LGOG 3 days ago, and have to agree with others that battery life is "iffy" at best - Android OS is my highest battery hog at between 60 and 70%
  17. #17
    jelong's Avatar
    Posts
    Global Posts
    2 Global Posts
    thanks man. It really works for my LG OG..
    Since I have installed this on last weekend, my battery life increased average 30%.
  1. "Android OS" Battery Drain Issue in ICS
    By TouchWizard in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-25-2013, 11:04 PM
  2. Android OS battery usage is higher than screen usage?
    By briansmithphotography in forum AT&T Galaxy S3
    Last Post: 08-17-2012, 02:29 PM
  3. Android OS battery usage
    By astraelraen in forum Verizon Galaxy Nexus
    Last Post: 12-20-2011, 01:01 PM
  4. Android OS battery usage
    By gm46 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-19-2011, 12:16 PM
  5. High com.android.mms battery use
    By Dragon1473 in forum Verizon HTC Thunderbolt
    Last Post: 05-20-2011, 10:52 AM
