11-11-2016 10:50 AM
42 12
tools
  1. heyitsjustme's Avatar
    For some reason my incoming texts aren't being accompanied by a sound. I definitely do not have the phone's sound off.
    How do I fix this?
    11-29-2012 09:13 PM
  2. Lanhoj's Avatar
    Try an App named "LightFlow" from the Google Play Store to see if it's working.
    11-29-2012 09:16 PM
  3. heyitsjustme's Avatar
    I just did that, but nothing. What am I supposed to do with it?
    11-29-2012 09:30 PM
  4. heyitsjustme's Avatar
    Anyone know?
    11-30-2012 08:35 AM
  5. Lanhoj's Avatar
    Are you using a 3rd party SMS App?
    11-30-2012 11:55 AM
  6. heyitsjustme's Avatar
    No, I literally just got the phone a few days ago.
    11-30-2012 07:29 PM
  7. steev89's Avatar
    I've noticed this happens when I have the txt messaging app still open when I lock the phone. I think what happens is the phone gets the message and it sees the app is still open so it doesn't notify you thinking you are looking at it already. Try exited the messaging app when you've sent the message and see if it fixes the problem. Its kind of annoying I know but the only solution I've found for it.
    12-04-2012 07:24 PM
  8. Evilgoose's Avatar
    Only thing I can say is make sure you didn't hit the sound profile icon in the drop down menu. I found myself doing that and would wonder why I wasn't getting sound sometimes. I just took it out of the drop down options eventually since I already have my audio setup how I want.
    12-05-2012 11:34 AM
  9. jasenr's Avatar
    This!! I noticed this exact thing myself.
    12-05-2012 04:12 PM
  10. Tramie's Avatar
    Hey, so this also happen to me and this is how I fixed it.
    1. Go to settings
    2. Application manager
    3. You will see three tabs : downloaded, running, and All
    You would want to flip to the tab that says "All", by just slide your finger across the screen to the left.
    4. When you're under the tab "All", scroll down ( this may take a few mins). slowly keep on looking until you see a "Messaging" icon and click on it.
    5. Under Force Stop and Disable, there should be a Check the box that said show notifications. Check that.
    6. Now you should have notification sounds for your text message.
    I hope it helps!!! =]
    01-11-2013 12:58 AM
  11. bdsm12's Avatar
    Hi guys did all this and didnt work.talked to a buddy and all we did was power off the phone and restarted it- sound was there!
    05-08-2013 12:00 PM
  12. Little Darwin's Avatar
    The old help desk first response to any problem, "Reboot, and see if that helps." It is good to see that the classic fixes still sometimes work.
    soterian87 and likwidkool like this.
    05-08-2013 01:55 PM
  13. burgboy's Avatar
    Go to message - setting - notification - sound notification - please check there.
    My G is normal with sound for incoming text messages.
    Gửi từ LG-E975 của ti bằng cch sử dụng Tapatalk 2
    05-08-2013 06:23 PM
  14. cckgz4's Avatar
    This happens while I'm on a phone call. I don't hear ANYTHING.
    05-09-2013 03:49 AM
  15. mbeezy815's Avatar
    Thank you Tramie! This was driving me nuts!
    07-01-2013 09:57 PM
  16. TTheInfamous1's Avatar
    1. Go to settings
    I just posted about this because I couldn't find anything on it. However my wife is having this issue and I tried what you suggest and still nothing. Any other suggestions?
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    08-30-2013 01:07 PM
  17. Wayne173's Avatar
    I've had a sound issue also and this is what i've noticed and done to fix or work around it. I to was losing sound to text notifications and ring tones. One day i noticed after playing a game i had paused it to talk to my kid. When the phone went into sleep mode i got a call from my wife and a text from her to call her. Phone never gave a sound notification. This has happened many times before and i lived with it until i found out what was going on in my case.
    Ok enough jabber.....i think the issue is with how the task manager deals with putting apps in sleep mode or how some devs write the audio portions of their apps. Here's what i did...
    1) Once you notice the sound is gone go to Settings, Sound and see if the volumes are turned off.
    2) Now go back to your home screen and hold down the Home button to get to the task manager and see what apps are running in the background.
    3) Start from the bottom and close the app by swiping it off the screen
    4) Go back and check settings, volume to see if the audio bars have shown that they have returned.
    5) Or you can clear all and go check the volume (but then you won't which app is the issue)
    6) If you do the one at a time method you may find an app that when put in sleep mode it will turn your volumes off.
    I have found this issue with three of the apps i use. I either deleted them or i just remember to close them out in the task manager when im done. The apps that gave me audio issues are Real Racing 3, Candy Crush, and HBO Go. Again this is what MY phone is doing (Sprint Optimus G) and how I'm dealing with it. I may be way off base but this is what fixed my audio issue.....for now.
    Posted via The OG
    09-02-2013 08:17 AM
  18. EllieJay76's Avatar
    Spot on, thanks a million, it was driving me crazy!!
    Ej
    09-09-2013 03:10 PM
  19. Wayne173's Avatar
    Ej
    Glad it worked for you.
    Posted via The OG
    09-11-2013 08:28 AM
  20. GhostTown_Willy's Avatar
    Here's the solution.
    Notification sounds exist in TWO places.
    1) Settings - Sound - Notification Sound.
    Doing anything here won't solve the issue.
    2) Click on the messages app in the dock along the bottom. Top left should say ALL MESSAGES.
    To the right it should have a Spotlight icon (looks like a magnifying glass, then a Plus sign icon,
    then three vertical dots. Click that.
    Click settings - then click Notifications - Click PLAY NOTIFICATIONS SOUND and also
    Choose the NOTIFICATION SOUND just below. Make sure you click APPLY for finish it off.
    That should help.
    "Rosebud"
    10-12-2013 03:32 AM
  21. Joanna Bailey's Avatar
    Thank you LanHoj who said to " Try an App named "LightFlow" from the Google Play Store to see if it's working." ! Thank you! I downloaded Light Flow Lite on my LG Venice because I had no sound notification accompanying my incoming text messages. (I just got the phone today) I went in to the app and changed the setting under MMS & SMS Apps. If you click on either of these and then scroll over to the sounds option you can enable sound!!! IT WORKED!!!! YEAH! Silly phone who needs an app to have a ringtone!
    11-08-2013 08:29 PM
  22. amoctober's Avatar
    Hi turning the phone off and rebooting worked for me also
    11-10-2013 07:31 PM
  23. saz89's Avatar
    Thanks
    11-12-2013 08:53 AM
  24. lscgt's Avatar
    Seriously, how do you guys prefer Android when something as simple as turning on audio alert for text message is nearly impossible to figure out.
    I have tried all of the suggestions in this thread and my UI options are all different and it does not work. It used to work; and then just stopped.
    Now, I can not figure out how to audio alert. It cost me money b/c I missed a job offer. I am thinking of switching to iPhone just b/c it is simple to set audio on/off for message; but is near impossible w/Android.
    11-14-2013 09:17 PM
  25. djc1945's Avatar
    If you are using AT&T as your provider, you must have AT&T messaging installed and working or standard messaging will not have a notification sound when new messages arrive. This may apply to other providers as well.
    01-11-2014 09:02 PM
42 12
  1. No picture for incoming call
    By hotis300boy in forum Sprint Epic 4G
    Last Post: 03-16-2011, 02:25 PM
  2. Default No ringtone for incoming call?
    By kingakoopa in forum Verizon HTC Thunderbolt
    Last Post: 01-26-2011, 01:21 PM
  3. not receiving some incoming text messages
    By azjerry in forum General Help and How To
    Last Post: 11-23-2010, 11:16 AM
  4. Replies: 7
    Last Post: 09-27-2010, 05:49 PM
  5. No sound for Video files transfered from EVO to Windows
    By pined-apple in forum HTC EVO 4G
    Last Post: 08-06-2010, 11:46 AM
