For some reason my incoming texts aren't being accompanied by a sound. I definitely do not have the phone's sound off.
How do I fix this?
Printable View
How do I fix this?
Try an App named "LightFlow" from the Google Play Store to see if it's working.
I just did that, but nothing. What am I supposed to do with it?Quote:
Originally Posted by Lanhoj [Only registered and activated users can see links. Click Here To Register...]
Anyone know?
Are you using a 3rd party SMS App?
No, I literally just got the phone a few days ago.Quote:
I've noticed this happens when I have the txt messaging app still open when I lock the phone. I think what happens is the phone gets the message and it sees the app is still open so it doesn't notify you thinking you are looking at it already. Try exited the messaging app when you've sent the message and see if it fixes the problem. Its kind of annoying I know but the only solution I've found for it.
Only thing I can say is make sure you didn't hit the sound profile icon in the drop down menu. I found myself doing that and would wonder why I wasn't getting sound sometimes. I just took it out of the drop down options eventually since I already have my audio setup how I want.
This!! I noticed this exact thing myself.Quote:
Originally Posted by steev89 [Only registered and activated users can see links. Click Here To Register...]
Hey, so this also happen to me and this is how I fixed it.
1. Go to settings
2. Application manager
3. You will see three tabs : downloaded, running, and All
You would want to flip to the tab that says "All", by just slide your finger across the screen to the left.
4. When you're under the tab "All", scroll down ( this may take a few mins). slowly keep on looking until you see a "Messaging" icon and click on it.
5. Under Force Stop and Disable, there should be a Check the box that said show notifications. Check that.
6. Now you should have notification sounds for your text message.
I hope it helps!!! =]
Hi guys did all this and didnt work.talked to a buddy and all we did was power off the phone and restarted it- sound was there!
The old help desk first response to any problem, "Reboot, and see if that helps." It is good to see that the classic fixes still sometimes work. :)
Go to message - setting - notification - sound notification - please check there.
My G is normal with sound for incoming text messages.
Gửi từ LG-E975 của tôi bằng cách sử dụng Tapatalk 2
This happens while I'm on a phone call. I don't hear ANYTHING.
