Results 1 to 14 of 14
- 11-29-2012, 09:13 PM
Thread Author #1
- 11-29-2012, 09:16 PM #2
Re: No sound for incoming text messages
Try an App named "LightFlow" from the Google Play Store to see if it's working.
- 11-29-2012, 09:30 PM
Thread Author #3
- 11-30-2012, 08:35 AM
Thread Author #4
- 11-30-2012, 11:55 AM #5
Are you using a 3rd party SMS App?
- 11-30-2012, 07:29 PM
Thread Author #6
- 12-04-2012, 07:24 PM #7
I've noticed this happens when I have the txt messaging app still open when I lock the phone. I think what happens is the phone gets the message and it sees the app is still open so it doesn't notify you thinking you are looking at it already. Try exited the messaging app when you've sent the message and see if it fixes the problem. Its kind of annoying I know but the only solution I've found for it.
- 12-05-2012, 11:34 AM #8
Only thing I can say is make sure you didn't hit the sound profile icon in the drop down menu. I found myself doing that and would wonder why I wasn't getting sound sometimes. I just took it out of the drop down options eventually since I already have my audio setup how I want.
- 12-05-2012, 04:12 PM #9
- 01-11-2013, 12:58 AM #10
Hey, so this also happen to me and this is how I fixed it.
1. Go to settings
2. Application manager
3. You will see three tabs : downloaded, running, and All
You would want to flip to the tab that says "All", by just slide your finger across the screen to the left.
4. When you're under the tab "All", scroll down ( this may take a few mins). slowly keep on looking until you see a "Messaging" icon and click on it.
5. Under Force Stop and Disable, there should be a Check the box that said show notifications. Check that.
6. Now you should have notification sounds for your text message.
I hope it helps!!! =] - 05-08-2013, 12:00 PM #11
- 05-08-2013, 01:55 PM #12
- 05-08-2013, 06:23 PM #13
- 05-09-2013, 03:49 AM #14
This happens while I'm on a phone call. I don't hear ANYTHING.
Currently sitting WITHOUT phone envy...
No picture for incoming call
By bigb82 in forum Sprint Epic 4GReplies: 28Last Post: 03-16-2011, 02:25 PM -
Default No ringtone for incoming call?
By kingakoopa in forum Verizon HTC ThunderboltReplies: 5Last Post: 01-26-2011, 01:21 PM -
not receiving some incoming text messages
By azjerry in forum General Help and How ToReplies: 0Last Post: 11-23-2010, 11:16 AM -
Notification sound (gmail or text message) going through headphones
By gregkang in forum AT&T CaptivateReplies: 7Last Post: 09-27-2010, 05:49 PM -
No sound for Video files transfered from EVO to Windows
By pined-apple in forum HTC EVO 4GReplies: 8Last Post: 08-06-2010, 11:46 AM
Reply
