Results 1 to 7 of 7
- 12-01-2012, 09:32 PM
Thread Author #1
LTE does not work on unlocked Optimus G
I just received an Optimus G and had to unlock it to be able to use it. I I unlocked it myself with a code and it worked. Then I entered and saved the current Rogers mms apn settings. But then I go to gsm/wcdma/lte, I don't get LTE or any data service and it shuts of my cell service as well. I have triple checked the current apn settings in maaany places and am sure that mine are entered correctly. Any ideas?
- 12-03-2012, 12:02 PM #2
Re: LTE does not work on unlocked Optimus G
Rogers LTE is on a 2600 Mhz band, Bell and Telus LTE are on 2100 band. Who was the phone originally locked to? Rogers has a specific model of the optimus G to support their 2600 Mhz network.
- 12-04-2012, 12:45 PM
Thread Author #3
It was originally on Bell
- 12-04-2012, 02:56 PM #4
- 12-04-2012, 06:23 PM
Thread Author #5
Yeah, i have found out that the Bell Optimus G does not support the LTE band that Rogers uses.
- 12-04-2012, 07:47 PM #6
May I inquire how you unlocked your Optimus G? An unlocked Optimus G is a Nexus 4 with LTE and SD card slot once it get rooted and replaced with a stock Nexus 4 ROM.
- 12-11-2012, 04:46 PM
Thread Author #7
I bought the unlock code on ebay and unlocked it using that.
I also had to enter the Rogers MMS and Internet APN settings. But mine doesn't have the SD card slot.
Juicedefender does not work on Gingerbread
By og_president in forum LG Optimus S Rooting, ROMs, and HacksReplies: 7Last Post: 04-10-2011, 12:07 PM -
[?] Does Swiftkey work on the Optimus
By callgood in forum LG Optimus SReplies: 14Last Post: 02-10-2011, 01:34 PM -
Paid content does not work on Android?
By Epic4g_fiver in forum General News & DiscussionReplies: 2Last Post: 01-03-2011, 10:22 AM -
Voice Search does not work on Android 2.2
By Trace509 in forum Motorola Droid XReplies: 6Last Post: 11-16-2010, 03:36 PM -
doubletwist does not work on OS 10.4.11
By dcdoes in forum Android ApplicationsReplies: 3Last Post: 09-01-2010, 05:57 AM
Reply
