Typing the letter Q.
Every time I try to type the letter Q, I get no response or the letter W shows up instead. anyone else having this problem? I've tried some different keyboards with no luck. It happens with anything that requires using the keyboard? Any help would be greatly appreciated.
Re: Typing the letter Q.
Mine does fine. Actually with my case and large fingers, I have to be pretty focused on any keys near the edge to be sure I hit them, but Q doesn't provide any specific challenges.
This could be a defect due to how the process of making the touch sensors on the outside embedded into the glass is brand new .
Mine did this, I had to send to get a new one. The new one works great, so its a defect with the phone.
Hm, mine only does this if I'm using my right thumb from an uncomfortable position. But otherwise, no it's usually fine.
I finally had the chance to take my phone in today, they took a look at it, and are sending a new one. They said a few of the sensors were not working properly. Thanks for all the input.
I'm noticing this a lot more lol. Is it covered by manufacturer warranty?
Sent from LG Optimus Prime G :D
How severe were your problems? Mine happens occasionally...It's not always reproducible.
One day it just stopped working and didn't fix itself.
Mine was consistent in not being able to type the letter Q, or anything else that would be in that section of the display.
