Re: Battery charge message
I would suspect bad hardware. Either the adapter or the USB cable hooked to it.
You shouldn't see this when you use the wall outlet. It's the wall charger that is likely bad, not the phone.
If you use a computer usb to charge, you'll see this message, but shouldn't for the wall.
Take the charger back to the store and ask for a new one.
Sent from my LG-LS970 using Android Central Forums
Thanks for the help. It was indeed a hardware/charger issue. Glad it wasn't the phone. Very happy with this LG.
