Results 1 to 4 of 4
    MikeDeTiger's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery charge message
    Hi all, I'm new to the Android world (and new to smartphones in general). Trying to catch up on about 7 years worth of mobile tech, so please bear with me. I'm very happy with my LG Optimus G, but when I charge it via wall outlet, I keep getting a message that says "Battery is charging slowly due to low electric current of TA/USB connection." I don't understand what this means. It does seem to charge way slow, though. I'm using the factory charger that came with the phone (Sprint model). I can charge it in the car with a car charger and indeed it does charge more rapidly and I don't get that message. This is not only annoying, but I assume that since I'm getting that message about it every time I plug it in, something is not right. Thoughts/help?
  2. #2
    Little Darwin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Re: Battery charge message
    I would suspect bad hardware. Either the adapter or the USB cable hooked to it.
  3. #3
    georgetanner's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You shouldn't see this when you use the wall outlet. It's the wall charger that is likely bad, not the phone.
    If you use a computer usb to charge, you'll see this message, but shouldn't for the wall.
    Take the charger back to the store and ask for a new one.
    Sent from my LG-LS970 using Android Central Forums
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the help. It was indeed a hardware/charger issue. Glad it wasn't the phone. Very happy with this LG.
  1. Battery charging case w/holster
    By csierra72 in forum EVO Accessories
    Last Post: 06-22-2010, 11:44 AM
  2. Battery charging time insanely long?
    By dakis#AC in forum Google / HTC Nexus One
    Last Post: 01-24-2010, 09:38 AM
  3. Battery Charging question
    By grifforama in forum HTC Hero
    Last Post: 12-15-2009, 09:55 AM
  4. 2.0.1 and battery charging
    By roguephoenix#AC in forum Motorola Droid
    Last Post: 12-11-2009, 06:01 AM
  5. Eris Charging and Battery Charging Dock?
    By cjohnson481 in forum HTC Droid Eris
    Last Post: 11-15-2009, 07:49 PM
