1. deaddeciple's Avatar
    I rooted my optimus g ls970 and now i cant use me phones wifi feature to link to my homes wifi any hints on what may have caused that problem
    01-29-2014 04:03 PM
  2. jinjin12's Avatar
    go into your bootloader and check your baseband, if it says N/A then you might need to reflash your modem. You should try this regardless, it might just work. just download the zip file, go into recovery, flash it, and reboot system.
    go here
    https://app.box.com/s/zp7q3kpme7ta0b.../10486202351/1
    download the "cwm-ATTJB-Radio.zip" file
    02-05-2014 12:21 AM
  3. rsammon977's Avatar
    Any idea where I would find a similar file for the E971 on Rogers?
    03-04-2014 06:19 PM
  1. Volume Control App with Scheduling, Lockout and Override
    By trd 4rnr in forum Samsung Galaxy S4
    Last Post: 07-18-2014, 06:14 PM
  2. Replies: 1
    Last Post: 06-11-2014, 07:41 PM
  3. Replies: 8
    Last Post: 02-21-2014, 05:14 PM
  4. Sms stock app problem
    By AlexiosS3 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-31-2014, 10:13 AM
  5. Need Help With Screen Lock!
    By NavyWifeHaines in forum Samsung Galaxy S4
    Last Post: 01-30-2014, 07:12 AM
