1. todd083's Avatar
    I have a sprint lg optimus g. a couple days ago i rooted my cell phone and downloaded cyanogenmod operating system. Upon using it i got a blue death screen showing on my phone. Went back into recovery. cleared my cache. Rebooted into the same os. My phone had no no carrier info on it. I go back to recovery mode and somehow someway my phones internal storage was totally wiped. No os program. I have clockwork as my recovery system but as i said no files are on the internal storage. I have tried several different things but no luck. Please please please is there anything that i can do to get it back up and running
    03-30-2014 08:43 AM
  2. Golfdriver97's Avatar
    Sorry to say, but I think you may be in trouble. You can't drag/drop files when the device can only go into recovery.
    Did you have USB debugging on before the device was wiped?
    03-30-2014 09:04 AM
  3. todd083's Avatar
    to be honest not to sure. when i go under device manager after i put the phone in download mode under the ports section it says lge android net usb serial port. Does that mean anything?
    03-30-2014 09:10 AM
  4. Golfdriver97's Avatar
    The only thing I can think of to try is loading a ROM again and flashing in recovery.
    From a Liquid Nexus 5
    03-30-2014 09:47 AM
  5. todd083's Avatar
    I appreciate the input. I have tried using the lg flash tool but im not sure bout the kdz files and how they work. I know the kdz file is a lg based file. Any more insight. Thanks!!!
    03-30-2014 09:51 AM
  6. Golfdriver97's Avatar
    Unfortunately, I am not very familiar with LG devices.
    03-30-2014 10:14 AM
  1. HTC One (M8): "Voice Roaming is on" Help
    By jerrad707 in forum HTC One M8
    Last Post: 04-17-2014, 07:25 PM
  2. Help an iPhone user convert
    By Tyler C1 in forum General Help and How To
    Last Post: 03-30-2014, 07:59 PM
  3. Please help!!
    By Ogredawg19 in forum AT&T Galaxy Note
    Last Post: 03-30-2014, 10:54 AM
  4. HELP! Firware Update Has Encountered A Problem!!!!!!!!!!
    By R0ach007 in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 03-30-2014, 09:35 AM
  5. Android Message..need help!
    By Harshuvinod in forum Samsung Galaxy Note 3
    Last Post: 03-30-2014, 12:36 AM
