1. LailaMckenzie's Avatar
    I dropped my lg-ls970 aka the optimus g
    and the top right corner of my phone cracked and chipped
    it looks like a wire is showing now ?
    and the top half of my screen lost its ability to work when touched. The screen is still in good condition and the lcd isnt messed up but im guessing the digitizer is bad? idk. but its the exact top half that fails to respond to touch. help? If i need to buy a new part can someone tell me what i need to get? or is it just the connectors inside that are bent, or loose?I need help figuring out what I need to do to fix my phone - im new to this/ help please. *pictures*-_57-2-.jpgI need help figuring out what I need to do to fix my phone - im new to this/ help please. *pictures*-_12.jpgI need help figuring out what I need to do to fix my phone - im new to this/ help please. *pictures*-_57-3-.jpgI need help figuring out what I need to do to fix my phone - im new to this/ help please. *pictures*-_12-1-.jpg
    07-11-2014 10:13 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sorry for your mishap--but unless you're really handy with fixing cellphones, I would recommend bringing it in to a repair shop. If you did it yourself, you would likely have to find the replacement parts online, then learn how to take the phone apart, and maybe do some fine soldering or other electrical work that I certainly wouldn't feel comfortable with.
    And next time, think about using a case!
    LailaMckenzie likes this.
    07-11-2014 10:18 PM
  1. Can an S4 on Cricket be unlocked to use on any other carrier?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 05-03-2015, 04:19 PM
  2. note 2 wired to 10.1 and retain touch
    By Unregistered in forum Ask a Question
    Last Post: 03-23-2015, 11:20 PM
  3. Replies: 1
    Last Post: 07-11-2014, 10:09 PM
  4. Replies: 1
  5. My huawei ascend pone doesnt want to work
    Last Post: 07-11-2014, 09:55 PM
