Results 1 to 2 of 2
    Default LG Optimus G From Sprint Overheated and will not turn on
    I had my phone pluged into my car Aux port, the phone stopped playing music I looked down at it. and it said it was overheating, then it turned off and never turned back on. I tried disconnecting the battery for a hour then plugging it back in. I did not fix the problem so I ordered a new battery online. I installed the new batter and I didn't fix my issue. does anyone have any advice to how I can fix this problem. phone is no longer under warranty :/
  2. #2
    Default Re: LG Optimus G From Sprint Overheated and will not turn on
    Welcome to Android Central? Does the phone have a user-removable battery, or was it intended to be non-removable? If the latter, it's always possible something happened when you opened the phone up.
    When you plug the phone into a wall outlet, does anything happen at all? Any LED lights go on? Have you tried keeping it plugged into a wall outlet overnight without disturbing it?
    Unfortunately, there's a chance that some circuits got fried. You might have to start looking for a new phone. Sorry!
  1. Issue with alarms and timers
    By andreo in forum Android Wear
    Last Post: 08-07-2014, 05:28 AM
  2. Replies: 6
    Last Post: 08-05-2014, 11:14 AM
  3. Samsung Galaxy Note 3 has a dead pixel line on display
    Last Post: 08-03-2014, 01:51 AM
  4. SD card not detected in ~ Settings;Apps
    Last Post: 08-03-2014, 12:38 AM
  5. camera on galaxy s5
    By Christian Diaz2 in forum Samsung Galaxy S5
    Last Post: 08-02-2014, 11:24 PM
