1. Kenshinfox's Avatar
    My Optimus L9 started slow charging no matter what I do. I plug it into the wall with the orginal charger and computer and it still slow charges.
    About a month before all this happened. I was trying to charge while the phone was off and it gave a charging with a yellow caution warning. Several weeks before this all happened MetroPCS pushed out an update for the phone and that is when I started noticing the problems.
    I also did a factory reset and still nothing. The android version is 4.1.2
    Is there a fix to this?
    05-15-2014 08:18 PM
  2. jbutewicz's Avatar
    Things that can fix this problem are unplugging and plugging in the phone into a wall ac adapter. The USB chargers usually charge slow.
    But since you did all of that I would suspect a faulty battery. I could definitely be wrong though.
    05-15-2014 10:57 PM
  3. Kenshinfox's Avatar
    It is slow with the ac adapter too.
    05-16-2014 12:32 AM
  4. Kenshinfox's Avatar
    How do I know if it is a faulty battery?
    05-16-2014 12:41 AM
  5. patrickstar777's Avatar
    I need to know that too pls, with my l9 battery drain issue.
    I'm about to buy a new battery. Weeks of observing have shown it's most likely a faulty battery in my case.
    I just wanna double-check before I spend money replacing a battery that was only well usable for a good six months.
    Thanks in advance
    09-14-2014 04:23 PM
  1. ATT GS5 will not stay charging in car........
    By Clayton Soffel in forum Samsung Galaxy S5
    Last Post: 05-17-2014, 01:58 AM
  2. G2 charging Issue
    By smbhb in forum LG G2
    Last Post: 05-16-2014, 06:43 AM
  3. Qi wireless charging
    By IBMJunkman in forum Samsung Galaxy S5
    Last Post: 05-15-2014, 09:53 PM
  4. can anyone fix my Galaxy S4 charging problem?
    By Edible Walrus in forum Samsung Galaxy S4
    Last Post: 05-15-2014, 05:02 PM
  5. Can't see SD Card in computer - LG Optimus F6
    By N7AS in forum General Help and How To
    Last Post: 05-15-2014, 12:30 PM
