09-28-2011 10:38 AM
77 1234
tools
  1. cmags's Avatar
    Best bet may be an external battery pack. They come in anything from 1000mAh to 5000mAh. About the same size as another phone, but some come with a belt clip, so you can either holster the phone or pocket it, with a cord coming from the battery pack charging the phone while its on your hip. Sold at most electronic stores, or on Ebay from China/Hong Kong for half the price.
    01-27-2011 06:30 AM
  2. Disaster's Avatar
    I bought these batteries also, and the ones with square corners do not fit the Optimus S. Also when I tried to get a refund the seller kept saying it fit the phone and I just contacted ebay and they refunded my money...thing is I see another KGIP 400N on ebay that looks different...check out this one Y576 2X Battery For LG Optimus S LS670 One P500 Android - eBay (item 270687291461 end time Feb-01-11 20:34:48 PST) use the zoom function and look at the corners they look more round and have too little dots... I am thinking this one will fit. I think they just put stickers on bootleg batteries and sell them on ebay But that battery with same sticker as the one I received looks like it has different corners and this guy knew about it had to have round corners. What do you guys think?
    I just bought batteries (and charger) from this same seller....UFO111. If you check his feedback you will see at least one auction for the same battery that is given a positive rating recently. You would think the person would not give a good rating if the battery didn't fit! Probably won't see them for a month or so. I'll let the forum know how they work.
    01-27-2011 09:16 AM
  3. debh945's Avatar
    Ok, I can give some feedback on these batteries by UFO111: Q576 2X Battery+Charger USB/AC FOR LG Optimus S LS670 - eBay (item 270692141528 end time Feb-11-11 16:15:25 PST)
    I ordered the two battery + charger deal here on January 11th and they just arrived today. I wasn't too hopefull after reading all the comments here but the batteries fit! I'm going to give them a full charge and try them out. I've bought Hong Kong batteries for all my previous cell phones and while they don't hold a charge near as well as OEM, they are cheap and nice to have as a backup!
    01-27-2011 07:05 PM
  4. Disaster's Avatar
    I've had mixed results with HK batteries, but they are hard to resist when you can buy a pair for $10 bucks for your camera, while the manufacturer wants $40 bucks for one. Sometimes they actually held more charge than the OEM batteries. The biggest concern is the current draw. Some of these new phones can draw a lot of current and you need a battery that can keep up.
    So far I've used non-OEM batteries in laptops, cellphones, cameras and video cameras and not had a single bad thing happen.
    01-27-2011 07:17 PM
  5. smccloud's Avatar
    Anyone know if there is an extended battery for the Optimus S? I would like to be able to know I can make it more than a day w/o charging if I have to.
    01-28-2011 11:19 AM
  6. apinkel's Avatar
    I don't believe anyone has found one for sure yet. There's a thread in the accessories sub-forum where folks are posting their experiences with different batteries.
    http://forum.androidcentral.com/lg-o...optimus-s.html
    01-28-2011 11:23 AM
  7. RUSH's Avatar
    Mugen Power 1800mAh Extended Battery for LG GM750, GT540, Optimus, GW620, GW820, GW880, GW825V, P500 Optimus One, GX200, GX500.
    Check either eBay or amazon.
    Good luck.
    01-28-2011 11:31 AM
  8. smccloud's Avatar
    Good luck.
    According to KSmithInNy, the Mugen Power one doesn't fit the Optimus S
    01-28-2011 11:32 AM
  9. RUSH's Avatar
    Bummer... guess you're fresh out of luck. Sorry!
    01-28-2011 11:35 AM
  10. hamagc's Avatar
    x2, no extended as of yet. not that anyones found atleast. look in the accessories section of the forum and you'll see a couple of battery threads.
    01-28-2011 11:37 AM
  11. dwb993's Avatar
    So what is the verdict on these? Good buy?
    02-11-2011 10:31 AM
  12. debh945's Avatar
    Yep! They seem to last as long as my OEM battery, maybe an hour or so less? Either way, I get at least 10 hours with heavy use from all three of my batteries so I'm happy. With my Hero I was lucky to get 1/2 that from a fully charged battery.
    02-11-2011 07:42 PM
  13. TVCCS's Avatar
    Just got this today for a V...and it fits...should fit the S as well.
    http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_3358wt_989
    02-15-2011 05:50 PM
  14. DoesItMatter's Avatar
    I ordered this for my Optimus S - will report back in a couple weeks and let
    everyone know if it fits or not!
    If it doesn't, I may try to cut the battery to fit - for $9 - might as well try.
    02-16-2011 03:17 AM
  15. DoesItMatter's Avatar
    Battery+Charger for LG P500 Optimus GW880 GX500 GX200 - eBay (item 280628191970 end time Mar-12-11 04:20:01 PST)
    Re-pasting the current bid in case you want to buy one!
    I just got it in the mail today - and it fits!
    Fits quite well, no issues, no having to make it fit - LG Optimus S
    Same rating as the stock - 1500 mah
    The extra charger also doubles as a spare battery holder - works good!
    Ordered on 2/16 - arrived on 2/26 - so 10 days from Hong Kong - not too bad!
    02-26-2011 07:19 PM
  16. nikc4's Avatar
    Hey DoesIt Matter,
    You mentioned cutting the battery to fit, and even though this battery did fit, do you think you could cut the mugen battery to fit? Can you cut batteries without hurting yourself? I threw one in a fire once, and i don't think i want to cut one of those open...they make ouchies.
    02-26-2011 09:35 PM
  17. DoesItMatter's Avatar
    Hey DoesIt Matter,
    From what I've heard other forum members say, the plastic casing of the battery had squared edges, where the stock battery for the Optimus-S has round edges. Since you'd just be cutting extra plastic off, it should not be a problem to trim off plastic. BUT - no idea how deep the plastic goes, so if you cut too deep and cut into the battery itself, you might end up destroying the battery and wasting all that $$. I'd just spend the $9 on e-bay and get one of those that I posted the e-bay link above. It's $9 and about 2-weeks of waiting.
    02-28-2011 11:39 AM
  18. dishe's Avatar
    Great find... ordered my $9 ebay special since my S has been complaining about charging an awful lot lately (every other day, I'll wake up to find that my phone gave up charging about 10 minutes after I went to sleep, and now has 10% left).
    Although I do wish I could get to the bottom of why this happens in the first place, having a spare on charge means no more downtime and guessing if my phone will be alive in the morning!
    Ordered today, from the link pasted earlier.
    03-01-2011 02:10 AM
  19. TVCCS's Avatar
    03-01-2011 02:59 AM
  20. mangust's Avatar
    My impression of the Optimus is that it was not really designed for swapping batteries -- I'd be worried about the battery cover wearing out with frequent swaps. In addition, if you are using a phone case case it could be rather cumbersome. Instead I opted for IOGEAR GMP1001B external battery. I bought mine form Newegg for $9 after rebate, but it's usually under $15. It works rather well - just like a slow USB charger, small and light (a bit smaller than the Optimus). The only thing I don't like is that it does not come with the micro-USB tip, so you end up using the Iogear charging cable, the USB female power tip, and a micro-USB cable.
    Put all these together while using your phone in public, and you are guaranteed to look like a dork.
    03-02-2011 11:21 AM
  21. cmags's Avatar
    You could always pick up a mini-USB to micro-USB charging cable, seemingly designed for this situation:
    Amazon.com: Wilson Electronics 859967 Micro - Mini USB Charging Adapter: Cell Phones & Accessories
    mangust likes this.
    03-03-2011 06:55 AM
  22. troyernet's Avatar
    I just got mine today (2 batteries, charger from Ebay) and they fit just fine. They have the rounded corners and are 1500 mAh same as the stock battery.
    03-03-2011 02:13 PM
  23. dishe's Avatar
    I've got two Duracell USB battery extenders and a Solar backup charger that I was given at a press event for mobile tech, and I used to use them on my old HTC winmo phones. But, honestly, they weren't worth the hassle 9 times out of ten, because I couldn't carry the phone around while attached for long enough to actually charge. Have you tried putting the phone + extender in your pocket while attached?
    Yeah, not happening unless you have a place to put the phone down, like on a desk. At which point, you might as well have a wall plug. When does this solution actually become useful? Because I couldn't find that scenario (except on a camping trip once, mostly because there was no outlet anyway, so I could leave the phone in my tent charging off the spare extender). So I picked up an HTC spare battery charger similar to the ones being recommended in this thread, and never touched the Duracell or Solar thing again.
    Plus, my problem is that my charging port seems to only work half of the time- I often wake up after plugging in my phone and finding that the battery quit charging part of the way in, and now I'm starting my day with 30% left. Spare battery is the way to go- swap and run.
    As for the case seeming "flimsy"... its not any worse than my older HTC phones. The Touch Pro had a pretty weak battery door, I was constantly afraid it would snap the little tab. Even worse was the mogul, and the TP2 wasn't too solid there either (although better than the other two).
    None of them ever broke on me, and I swapped batteries daily- other parts of the body started to go long before the battery door, it appears. I wouldn't be too concerned about that at all. It might look flimsy, but I think it will take a beating.
    03-07-2011 11:37 AM
  24. cruiserandmax's Avatar
    Today I dropped my phone in the water at the beach and it's basically dead now. I have insurance that is going to replace the handset but not the battery. I'm anticipating that the battery will also need to be replaced so I looked on eBay, and there are tons of auction for "NEW Cell Phone BATTERY for Sprint LG Optimus S LS670" that amount to about $4 shipped. This seems unusually cheap to me- but I'm not sure since I haven't actually had to replace a lion battery for any device I've owned... Are batteries just cheaper these days or should I be weary of these offers?
    03-12-2011 11:16 PM
  25. ajskhan's Avatar
    I, too, am interested in this!
    03-13-2011 11:20 AM
77 1234
