1. BBguy08's Avatar
    I think this should be a sticky for sure. If you buy one of those cheaper aftermarket Batteries for LS670 LG Optimus S the sides are flat and not rounded and the battery doesn't fit in the phone it just keeps popping out and you can't put the cover back on your phone.
    I think the only batteries that work are the LG branded ones right?
    01-22-2011 01:48 PM
  2. pmpmstrb's Avatar
    I do not believe there are any aftermarket batteries out for the S as of right now. Some people have tried and came up empty handed. http://forum.androidcentral.com/lg-o...optimus-s.html
    01-22-2011 02:42 PM
