Results 1 to 2 of 2
    BBguy08's Avatar
    Posts
    Global Posts
    18 Global Posts
    Default Aftermarket Battery Doesn't Fit - Watch Out!
    I think this should be a sticky for sure. If you buy one of those cheaper aftermarket Batteries for LS670 LG Optimus S the sides are flat and not rounded and the battery doesn't fit in the phone it just keeps popping out and you can't put the cover back on your phone.
    I think the only batteries that work are the LG branded ones right?
  2. #2
    pmpmstrb's Avatar
    Posts
    ROM
    ThundeRom v1.6.2 @ 806mhz
    Default
    I do not believe there are any aftermarket batteries out for the S as of right now. Some people have tried and came up empty handed. http://forum.androidcentral.com/lg-o...optimus-s.html
