04-23-2012 06:43 PM
1,468 1234 ...
tools
  1. sfhub's Avatar
    [How-To] Simplified UNROOT and return to STOCK
    (near the bottom on the op) *you can skip the rest of the op* -the direct links are in the op
    BTW I updated the link you provided to use V9 recovery. Previously I had updated to use VD recovery since VD was rootable using gingerbreak. Now I switched back to recommending V9 recovery so you can root VH.
    09-15-2011 01:28 AM
  2. sfhub's Avatar
    I whipped up some quick instructions to root ZVH:
    http://forums.androidcentral.com/lg-...tructions.html
    These are temporary instructions until someone comes up with some nice pretty *****-proof instructions.
    scrosler likes this.
    09-15-2011 02:43 AM
  3. scrosler's Avatar
    Thanks for doing that! Now that I hosed my config I am going to follow those and see how they work out for me. I will let you know.
    09-15-2011 02:44 AM
  4. sfhub's Avatar
    I'll be around for another 1/2 hour or so and can assist if you run into issues. Just post on that thread and I'll respond, hopefully quickly.
    09-15-2011 02:49 AM
  5. strra's Avatar
    has anyone had any success with an OC kernel? xionia (both OG and redux) and picasticks give some pretty nasty lag and graphical issues (for me anyway)
    09-15-2011 02:53 AM
  6. donbudafuko's Avatar
    Ok got the recovery installed an now i am getting a signature abort? Not sure to do
    09-15-2011 02:54 AM
  7. scrosler's Avatar
    I have not. Its prolly because those kernels are for 2.2?
    09-15-2011 02:54 AM
  8. sfhub's Avatar
    If you are trying to flash ZVH, then you probably have the wrong update.zip
    If you have already flashed ZVH and are trying to root it, then that is an expected error.
    09-15-2011 02:57 AM
  9. strra's Avatar
    well, xionia is for CM7
    i understand the incompatibility risks, i just wanted to make clear that i tried them
    09-15-2011 03:00 AM
  10. donbudafuko's Avatar
    im trying to flash i did all the steps to get recovery an i downloaded the ee........update.zip renamed it to update.zip an wen i try to flash it it comes up that ill try to download from one of the other mirrors
    09-15-2011 03:06 AM
  11. scrosler's Avatar
    Ok, I updated post #2 as follows!
    Follow these directions to the T and you will have no issues flashing this ROM!
    [WARN]Prerequisites
    Must be at latest Sprint VH baseband and rooted. More Info here: http://forums.androidcentral.com/lg-...tructions.html
    Must have a custom recovery installed. More info Here: [Custom Recovery] Xionia Clockwork (CWMA v1.2518.6)
    [/WARN]
    09-15-2011 03:34 AM
  12. mike9670's Avatar
    Hopefully it won't be long before we have a ROM that you don't have to do the V9 backwards route to get to a custom ROM
    09-15-2011 05:38 AM
  13. donbudafuko's Avatar
    Wouldn't drews gingerkernal work for this an its oc enabled an it is built off the lg source if I remember right
    09-15-2011 06:03 AM
  14. drewwalton19216801's Avatar
    GingerKernel WILL work with this ROM, and it's overclocked
    09-15-2011 06:22 AM
  15. deadset's Avatar
    Using this rom and also with GingerKernel; it is working nicely so far. I can't get Wi-Fi hotspot to work although I'm sure that is normal and will be fixed soon enough. Glad to be on official gingerbread finally!
    Edit: Haha right after I said this my phone freezes at the browser with Wi-Fi enabled and reboots. Haven't overclocked it yet. Not sure whats up.
    Edit2: Frozen at Sprint now... :\ bah
    09-15-2011 07:13 AM
  16. strra's Avatar
    when i flashed that, i got a boot loop fluke?
    09-15-2011 07:51 AM
  17. drewwalton19216801's Avatar
    I think I screwed up the default OC settings, I'm uploading a new kernel build at the moment.
    Edit: Released.
    09-15-2011 08:44 AM
  18. deadset's Avatar
    Edit: Released.
    Yeah I actually had it reboot when it was just sitting on my desk and not in use. Updated to v03... seems like the rebooting has stopped now. Is Wi-Fi hotspot something that will require the kernel to be updated/changed?
    09-15-2011 09:10 AM
  19. ccrs8's Avatar
    Thanks for this ROM! I just went from Nick's Shell ROM to this (after updating to gingerbread and rooting, of course). It seems to work great. I'll report any issues I have.
    I don't know if you are going to continue developing and adding features to this, or if you were just putting this out there as a de-Sprinted stock ROM for those who didn't want the bloat. As I said, I came from Shell ROM so clearly I don't do the "bells and whistles" that others like. The only suggestions or requests I'd have would be a) get rid of the bootup sound, and b) give an option to only have the lock key be able to unlock the phone to reduce the chance of butt dialing. I tried to flash a keyboard layout .zip from Reborn that got rid of the home button wake-up, but that doesn't seem to work on this ROM.
    Anyway, thanks a ton!
    09-15-2011 10:44 AM
  20. scrosler's Avatar
    Thats good stuff!!!
    Edit: Released.
    Drew, I dont see any updates. Last update was 9/8? What am I missing?
    Hot spot needs to be reworked. It wont be going until I can figure out the hacks that need to be rebuilt on the framework.
    0. I plan on contributing. This is my third ROM series for the Optimus S and I have two ROM series for the Evo 3D (Not sure where that came from?).
    1. Good request!
    2. I dont understand what you mean about unlock key? Can you link me to an example?
    3. I cant say that I am shocked to hear that mods built for Froyo dont work in Gingerbread. lol
    -Scott
    09-15-2011 11:19 AM
  21. kingdavidbaker's Avatar
    I think he means he doesn't want the phone to unlock unless you hit the power button. When stock many buttons will wake the screen....which I prefer lol....but apparently some people have issues butt dialing even with a lock screen. And just so everyone is aware you can change the keyboard settings yourself by editing your thunder.kl file. There are instructions in a thread somewhere lol.
    Edit: I haven't flashed the ZVH update or gROM so I'm assuming the keyboard file is still "thunder.kl"
    scrosler and ccrs8 like this.
    09-15-2011 11:23 AM
  22. scrosler's Avatar
    Ohhhhh.... Ok. Yeah, I got you now. Makes sense. On my 3D it doesnt do that and I never have butt dial issues anyways, lol. But I will look into that.
    Keyboard: I believe so as well. I cant say for sure because I am away from the ability to check...
    09-15-2011 11:35 AM
  23. jbyers715's Avatar
    I just flashed this morning and looking good. I do have one issue though. If I plug the phone in via USB to a machine that has the LG drivers, it will charge and ask for USB Mass storage everytime. If I plug into a machine without the drivers, I have to enable/disable USB debug to charge and I never get prompted for USB Mass storage.
    09-15-2011 12:10 PM
  24. scrosler's Avatar
    Ok... Thats strange. I cant say that I am having the same results but I will try to replicate and let you know what I find.
    09-15-2011 12:12 PM
  25. ccrs8's Avatar
    Thanks. That is still the file. The thread about it is here:
    [MOD] Remap your hardware keys
    I followed the instructions in that thread and set the four physical buttons below the screen to NONE from their original setting of WAKE_DROPPED and rebooted, and now everything is good. Of course that will probably get overwritten next time I flash, so next I need to learn how to create a flashable .zip to make those changes easier.
    09-15-2011 12:12 PM
1,468 1234 ...
