vapore0n
Just an update for my push notification problems. Tried out K9 Mail again. I receive push notifications intermittently, but it's not instantaneous like it was on Froyo with stock GMail. I think I've set up K9 to only use IMAP IDLE, but it chews up my battery like crazy, so I can't help but think that it's doing more than just listening for push notifications (POLLing?). In other words, I don't know that it's the best measure for how functional push is.
I also tried the official Twitter app. I've never used it before, but I'm assuming it's supposed to send you a notification whenever a feed is updated; if I'm wrong, my apologies. Anyways, I don't receive any push notifications. The only time the feeds appear to be updated is when I open the app and tap the feed column.
Are there any other apps that I can try to see if push is working?
Ill see about testing my push issues again tonight.
If you have hotmail, you could install the hotmail app. This one drains battery too though.
More push email testing.
Using gmail.
Last night I restored a nandroid backup of when I upgraded to zvh and rooted. Did a clean install of grom 2.2; clean cache and phone reset (or whatever is called on the xionia menu).
This morning I sent myself an email, 20 mins later nothing.
I received emails while driving to work while I was using Pandora though.
Tonight I gave it more tests. 1 hr idle time then use laptop to send email to myself (hotmail to gmail,yahoo to gmail, work to gmail). 20 mins in between emails. They all seemed to work good.
Tomorrow ill send myself more in the morning. If it works good, its time to make another nandroid backup.
Tested flash. Works awesome! Too bad Sprint is not
