Page 1 of 15 1234 ... LastLast
Results 1 to 25 of 354
Like Tree94Likes
    drewwalton19216801's Avatar
    Posts
    ROM
    HydroROM
    Default [WIP][ROM] CyanogenMod 9 for LG Optimus S (Yes, it's ICS!)
    CyanogenMod 9
    Android 4.0.3 Ice Cream Sandwich for LG Optimus S
    ICS on Optimus S? Really?!
    Yes, really. This is a direct port of the CM9 Beta ROM by lupohirp at XDA-Developers. Credit for getting CM9/ICS up and running on the Optimus One goes to lupohirp, and the original thread can be
    What's working:
    1) Phone calls (incoming & outgoing)
    2) Wi-Fi
    3) Bluetooth
    4) Sound
    5) Touchscreen (including Multitouch!)
    6) Accelerometer sensor
    7) Proximity sensor (screen off during call)
    8) USB Mass storage
    What might be working (untested):
    1) The rest of the sensors
    2) Bluetooth devices (read more info below)
    3) HW Acceleration
    What's NOT working:
    1) Data
    2) Text Messaging (including MMS)
    3) Live Wallpapers
    4) Camera
    5) Offline charging
    6) Other stuff I forgot...
    What's acting strangely:
    1) Launcher wallpapers
    2) Buttons on the phone (see more info below)
    More info on Bluetooth:
    The Bluetooth chip is working and gets activated properly. I was able to successfully pair with a Bluetooth headset, however pressing a button on the headset caused an FC. This needs more testing.
    More info on the buttons:
    All of the physical buttons work as expected, EXCEPT the Home and (side) Search buttons. The Home button acts like the Up button on a keyboard. This is probably a simple fix but I haven't been able to track it down yet. The side Search button isn't high priority but it does nothing.
    Screenshots:
    Download:
    By clicking the link below, you agree that this ROM is a work-in-progress. As such, many things will be broken or behave strangely. You also agree that this ROM is only to be flashed on devices using the LS670ZVH baseband. In order to flash this ROM, you will need to turn signature verification off in recovery mode.
    Credits:
    CyanogenMod Team
    lupohirp for hacking CM9 like a boss
    The almighty Dooderbutt
    Thanked by 45:
    + Show/Hide list of the thanked
  2. #2
    jstntp's Avatar
    AC Forums Android Developer
    Posts
    ROM
    aosp - JellyBean
    Default
    Oh yes he did folks! Nice job bud!
  3. #3
    basketthis's Avatar
    Posts
    Global Posts
    1,456 Global Posts
    ROM
    AOSP!!!
    Default Re: [WIP][ROM] CyanogenMod 9 for LG Optimus S (Yes, it's ICS!)
    No. Way.
    What a beast.
    "Th- th- thinking of a master plan"
    Thanked by 2:
  4. #4
    Awesome! Maybe we can finally retire that thread with sandwich spelled wrong in the title lol
    Thanked by:
  5. #5
    formula355's Avatar
    Posts
    ROM
    Pete's ICS, Matr1x Kernel
    Excuse my ignorance, but I didn't see it listed anywhere. Is this for VD or VH? I want to try it out but I kind of need my text messaging. Maybe I'll wait and see if someone tests it on a spare phone.
    This is awesome, btw! I've played with some ICS themes and the ICS Launcher and I'm loving it. So this will be awesome!
  6. #6
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    Get outta here! Drew for President!
    Va1ha11a likes this.
    Posts
    ROM
    HydroROM
    Quote Originally Posted by formula355 View Post
    It's for ZVH, and likely will never work on ZVD. If you're expecting a daily driver, move along because this is NOT a daily driver.
  8. #8
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Cool. Great work.
    Probably will need to change
    android.hardware.telephony.gsm
    to
    android.hardware.telephony.cdma
    And fix the sprint apn in apns-conf.xml. CM still uses the broken sprint one.
    Mms overlays and Framework overlays for sprint should fix the sms/mms.
    Edit. Depending if apktool can decomplie ICS frameworks, it gave errors last time i tried.
    Thanked by 3:
    drewwalton19216801 likes this.
  9. #9
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Awesome you are awesome all hail drew
  10. #10
    formula355's Avatar
    Posts
    ROM
    Quote Originally Posted by drewwalton19216801 View Post
    Thank you sir. I didn't figure this would be considered a daily right now. I'm on Hydro at the moment so I'll stick with that for now.
    What are the possiblities of this becoming a daily driver ROM in the future?
  11. Thread Author  Thread Author    #11
    Posts
    ROM
    HydroROM
    At this point? Slim to none.
    And thekraven: good call on the APN config, I'd forgotten that the CM tree contains non-working Sprint APN configs.
  12. #12
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    in the next beta shall mms work
  13. #13
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    what kernel works
  14. #14
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    would text + work
  15. Thread Author  Thread Author    #15
    Posts
    ROM
    HydroROM
    GingerKernel is included and works, no need to change kernels (what kernel would you even change to??).
    SMS/MMS is not working, and I won't give any ETAs as to when it will work. Please don't clutter this thread with feature requests and things like "when will this work?!?!?"
  16. #16
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    How exciting !! I will definitally be trying this soon.
    Edit: Can it be assumed that google voice will work for texts when wifi is activated?
  17. #17
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    is this beta 2 found on xda thread and if so where are the gapps
  18. Thread Author  Thread Author    #18
    Posts
    ROM
    HydroROM
    Quote Originally Posted by jonny5449 View Post
    If you will read the first post, you will know that it is based on lupohirp's P500 CM9 port (which is currently Beta 2). There are no Gapps for ICS that work on MDPI screens that I know of.
  19. #19
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    im trying the goo inside me gapps see how it works
  20. #20
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Regarding the gAPPs, I expect that Drew is correct. However, you might try some of the packages here and report back with your results:
  21. #21
    Can you please release for Virgin Mobile Optimus V and/or Slider?
    Google+ Devices: HTC Mogul, Touch, TP, TP2, Samsung Moment & Intercept, Motorola Triumph, LG Optimus V & Slider, Nook, Iconia Tab, HTC Sensation
  22. #22
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    testing ics goo inside me for android versions 4.x which means 4.0 and up
  23. #23
    ikeywatson's Avatar
    Posts
    ROM
    jellybeanLIH leak
    it is for zvh
  24. #24
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Quote Originally Posted by ikeywatson View Post
    it is for zvh
    yes its for zvh just flashed now trying random ics gapps
  25. #25
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    it worked go on the thread epidemus posted and look for ics gapps get the one that is the newest version you will have to install market by apk
    Thanked by:
    epidenimus likes this.
