DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Page 1 of 9 1234 ... LastLast
Results 1 to 25 of 218
Like Tree28Likes
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default [Rom][WIP][ZVD] Slimmed CM10 Alpha 6
    USE THIS RECOVERY OR ROM WONT FLASH
    [RECOVERY] Cannibal Open Touch v1.2 (latest update: 06/24/2012)
    XIONIA will work too!!!
    hello all first i want to say before we get started this is a port of a port
    next i will not be working on this all the time but often because this will just be synced with zakman's build and try to work out possible problems so wish me luck
    next i have not tested so dont know if it boots but it should
    next it has the quattrimus kernel until i can unpack boot.img and include the kravens kernel(Go flash the 15th one its faster)
    I'm not responsible for brickings
    Lets get started
    this is zakman's rom so it has ALL features as the v one i just switched a couple files so it works i used no base so did not need permission for rom bases
    This is cm10 not cm9 or cm7 or anything else its cm10 so only discuss this not anything else.
    fixes or help with the rom Would be greatly appreciated
    also no jellybean goodies YET
    HOW TO FLASH
    1.use pre flash wipe in drews recovery or just wipe all if in a different one
    2.disable signature verification
    3.flash rom
    4.flash gapps
    5.boot android
    6.profit
    what works
    phone
    sms (sending and getting)
    gps
    wi-fi
    3g
    sound (speaker and headphones)
    all the basics but theres more that works
    Google Now
    Google ears
    Theme engine
    what doesnt work
    mms
    Issues-
    1.when apps are moved to sdcard they are uninstalled so dont move apps to sd card
    3.any downloaded zip,apk or other files will not show up until reboot
    5. Deep sleep
    rest of the issues are not noticeable so not much problems
    Download rom-
    Zakmans gapps fixed Google ears- FLASH THESE GAPPS FOR BETTER APP COMPATIBILITY
    zakman's thread-http://forums.androidcentral.com/opt...optimus-v.html
    thanks
    torch2424- for inspiring me (YOU DA MAN)
    zakman- for letting me port
    TDM- kernel
    Cyanogenmod-being awesome
    android-for making jellybean
    the first person who rooted the optimus s- for rooting it and making it so we can make good roms like this
    Drew-For originally got cm10 booting on the optimus s
    nitestalkr-apps2ext (THANK YOU)
    Changelog
    8-9-12 initial release
    8-10-12 fixed sdcard moving problem see instructions after this
    8-12-12 added amphetimes, replaced a lib file that zakman replaced (Will say what it is in a minute i forgot),signed
    8-14-12 added a better launcher apex
    8-21-12 Better launcher (Stock Trebucket jellybean launcher modded), Bobzhome kernel (Much Faster), Google now fixed mostly,Audio files fixed,Better GPS for improved acuracy,Better app Compatibility (ics compatibility i think),Theme chooser (not working yet), new RIL files added better reliability,Youtube app i think,Build.prop changes (WOOT WOOT BIG UPDATE)
    Fix Google Now
    1.Flash Rom
    2.Flash Gapps that i posted not my old ones or other old ones
    3. install this-
    4. install this-
    5.Profit
    do not move apps manually to sdcard let the scripts do it
    also every time you flash this rom if you had apps they will be there due to scripts
    You must have a 512 mb ext3 or ext4 partition for this ROM to work properly i prefer 1gb
    i recommend Apex Launcher its MUCH more smoother sorry didn't include will re-include in next build.....
    SCREENSHOTS!!!
  2. Thread Author  Thread Author    #2
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default Re: [Rom][PORT OF A PORT][ZVD] CM10 Jellybean
    Here's my current to do list for the rom
    1. Fix MMS
    2.fix camera
    3.fix roaming indicator as its annoying
    4. Slim down rom
    5.continue to fix problems
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Upcoming in next build/alpha 6
    1.Fixed camera for sure
    2.Mms maybe will givit a shot
    3. Roaming indicator off will be replaced by sprint
    4.add apex launcher
    5.slim down bobz rom to 80 mb I did it with Godzilla and added tweaks so maybe it will go lower
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Reserved
  5. #5
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    Don't upload tihs that you haven't tested. Thank you and thank you.
    Please label your post as an alpha build and warn those adventurous new folks who might expect more.
    Have you obtained permission for all the work that you have included? I don't see tdm even mentioned in your post, yet you are using a kernel from his ROM?
    Other than likely changing out the files in nitestalkr's patch that allows Opti V ROMs to run on the Opti S, what changes have you made? Where is your mention of his work?
    A very prominent contibutor was just raked over the coals in the E4GT thread for similar mistakes, so this is your polite advisory.
    If you are inclined to spend a lot of money and want a pretty trophy with which to pass the next few years of your life that talks to you in a condescending voice, can't navigate to save its life, expects full control over all you do, demands $13 for a $3 purchase, allegedly has a single recessed button, needs an expensive computer and a credit card to do anything, hates your music and has purses designed just for it...
    Get married to someone you hate... or get an iPhone.
    New to LG's premium Android phone? Check out the Optimus S Welcome Guide.
    Used ROM Mangler on your Optimus S and having problems? Try this.
    Warlord721 likes this.
  6. #6
    andrewnelson23's Avatar
    Posts
    ROM
    Quattrimus
    Quote Originally Posted by epidenimus View Post
    Other than likely changing the files in nitestalkr's patch that allows Opti V ROMs to run on the Opti S, what changes have you made? Where is your mention of his work?
    A very prominent contibutor was just raked over the coals in the E4GT thread, so this is your polite advisory.
    Zakman had permission from drew to port his cm10(which included tdm's kernel). After that, Jonny has permission from Zakman to port his rom. Also, even though Nitestalkr developed the whole .zip for the OV-OS fix, he did not discover what allowed them to be interchangeable. If I'm not mistaken, Zakman was the first one to actually mention which .so files needed to be replaced.
    Thanked by 2:
  7. #7
    Posts
    ROM
    Quattrimus
    Yes, he was the one that found how to make ov and os roms interchangeable.
    Quote Originally Posted by Zakman View Post
    WE HAVE ZVD!!!!!! I CAN CONFIRM ZVD AND WORKING ON VIRGIN NETWORK!!! I FIXED IT!!!! Im on ZV4. I replaced libgstk_exp.so, libpbmlib.so, libwms.so from His Jelly Bean Port to the same files from the ics port AND IT WORKED!!! ZVDD!
    [beast]
    and since he has permission from Zakman, no worries. From my viewpoint, he's given all due credit to all things that he has referenced from... = Zakman. But he's also given credit to tdm and Drew in the end of his post. Which was currently last edited 'yesterday at 11:19 pm.' When you wrote your little critique, it was 'today at 12:52' and last edited at '1:21'. So chill a bit man, and read the whole op.
    Thanked by 2:
  8. #8
    Posts
    ROM
    Quattrimus
    Also, @Jonny, I gave Zakman a modified jb latinIME.apk to use that cut the app down SEVENTEEN MB!!! So it's down to 2 MB. It's somewhere on the OV thread, and I found the apk from a guy at xda, which I referenced in that post. You could use that to cut down the rom a bit. Zakman is going to do that in the next alpha anyway I believe.(he might already have, but I don't think so.)
  9. #9
    Default
    Lol? A Port of a Port. Good luck.
    Is TheKravens kernel gingerbread too?
    Thanked by:
  10. #10
    Seems to be working quite well, great job! Keep up the good work. And agreed andrewnelson.
    Thanked by:
  11. Thread Author  Thread Author    #11
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by andrewnelson23 View Post
    Its already included
    I'm trying something else to fix apps moving to SD I fixed but lost home button:banghead::banghead:
    Working on it
    Sent from my LG-LS670 using Tapatalk 2
  12. #12
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Default
    What did u fix?
  13. #13
    Default
    I'm wondering ...
    Is this Zakman's build with Sprint stuff, or is is a port?
  14. Thread Author  Thread Author    #14
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    What did u fix?
    The moving apps 2 SD but screwed up home button
  15. #15
    Shinkenred's Avatar
    Posts
    ROM
    CM10-BobZhome
    Interesting...but with the whole issue of apps2sd, I think I'll just wait until it's all fixed to try this puppy out. (I have A LOT of apps, and I certainly NEED the space; but I don't want them becoming corrupted as a result of this glitch.)
  16. #16
    r0gu3dev1pr's Avatar
    Posts
    ROM
    BobzHome's CM10
    Default
    You should reach out to ShadowEO. He created a boot.img based off of Kraven's CM9 which included app2ext scripts. Maybe he can shed some light on the issue.
    [MOD][A2SD] Mounts2SD [DISCONTINUED, READ OP FOR INFO]
    Sent from my LG-LS670 using Android Central Forums
    Thanked by:
  17. Thread Author  Thread Author    #17
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by r0gu3dev1pr View Post
    I already fixed it uploading build now
    Thanked by:
  18. Thread Author  Thread Author    #18
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    I thought I fixed but I was wrong its still broken
  19. Thread Author  Thread Author    #19
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    fixed again
    ok download a root explorer
    give permission to all files in int.d folder except 00banner (Dont touch that)
    change all other files to permission r/w/x
    reboot you must move apps 2 sdcard again (WEIRD) but must be done this is with new update im updating OP with will put instructions in OP too
  20. Thread Author  Thread Author    #20
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    OP updated
  21. #21
    Shinkenred's Avatar
    Posts
    ROM
    CM10-BobZhome
    Default
    Quote Originally Posted by jonny
    ...wait, what the deuce!? You mean The ROM doesn't already have Root Explorer or File Explorer built-in like most!? That's odd...
    Sent from a Purple LG-LS670 with CM9...the New Wolzard Phone...yes.
  22. Thread Author  Thread Author    #22
    jonny5449's Avatar
    AC Citizen
    Posts
    ROM
    Cm7/Cm9/Cm10
    Default
    Quote Originally Posted by Shinkenred View Post
    I know lol I got permission from jrummy to include his in next build will have sorry but trust me its worth
  23. #23
    jasonevil's Avatar
    Posts
    ROM
    CM9
    would this work for google now
    Thanked by:
  24. #24
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by ThatGuyLurkin View Post
    I'm wondering ...
    pretty sure its zakmans with sprint stuff....
    Guess whos coming back!
    Thanked by:
  25. #25
    Default
    Quote Originally Posted by jasonevil View Post
    I believe that's what everyone else is using. :P
